Running unraid and nextcloud in docker container. using SWAG as the proxy
and MariaDB for PHP
Unable to change the max upload beyond 512MB
Nextcloud version: [Nextcloud Hub 6] (27.1.3) - in docker
Operating system and version: Linux 6.1.49-Unraid x86_64
nginx version : swag 2.7.4 - in docker
PHP version : mariaDB 8.2.10 - in docker
Unable to upload more then 512MB
Is this the first time you’ve seen this error? N
Files I have change to try to change the setting
/mnt/user/appdata/swag/nginx/proxy-confs/nextcloud.subdomain.conf
server {
listen 443 ssl http2;
listen [::]:443 ssl http2;
server_name nextcloud.*;
include /config/nginx/ssl.conf;
add_header Strict-Transport-Security "max-age=15768000; includeSubDomains; preload;";
client_max_body_size 60G;
fastcgi_buffers 64 4k;
client_body_temp_path /tmp/nginx_client_bodies;
location / {
include /config/nginx/proxy.conf;
include /config/nginx/resolver.conf;
set $upstream_app 192.168.3.12;
set $upstream_port 444;
set $upstream_proto https;
proxy_pass $upstream_proto://$upstream_app:$upstream_port;
# Hide proxy response headers from Nextcloud that conflict with ssl.conf
# Uncomment the Optional additional headers in SWAG's ssl.conf to pass Nextcloud's security scan
proxy_hide_header Referrer-Policy;
proxy_hide_header X-Content-Type-Options;
proxy_hide_header X-Frame-Options;
proxy_hide_header X-XSS-Protection;
# Disable proxy buffering
proxy_buffering off;
proxy_request_buffering off;
proxy_max_temp_file_size 0;
in the nextcloud docker terminal
/etc/php82/php.ini
upload_max_file_size 65536M
post_max_file_size 65536M
max_input_time 3600
max_execution_time 3600
memory_limit 2048
For the life of me I can not get nextcloud to update the max file size or the memory size. How do we have a vlaue that is impossible to change and why must we configure this in a .ini file. Why is this not configurable within nextcloud GUI? I feel whoever coded this 512MB limit is still using floppy disks on their computer. I sync my phone photos/videos a new phone that records video in 4k easily exceeds 512MB fairly quickly.
