I get the following error when I open the apps page:
Could not connect to appstore: cURL error 7: (see https://curl.haxx.se/libcurl/c/libcurl-errors.html)
Our server does not have internet connection but I did configure a proxy.= in config.php:
'instanceid' => 'nvt',
'passwordsalt' => 'nvt',
'secret' => 'nvt',
0 => 'nextcloud-t.example.com',
'version' => '20.0.7.1',
'overwrite.cli.url' => 'https://nextcloud-t.example.com',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'nvt',
'ldapIgnoreNamingRules' => false,
'debug' => true,
'loglevel' => 1,
'proxy' => 'proxys.example.com:8080',
'proxyexclude' => ['.example.com'],
'default_language' => 'en',
It does not look like the proxy server is used, I do not see a connection when I use tcpdump, when I curl to the appstore from the command line I see traffic in tcpdump and it works.
I use nextcloud 20.0.7
