Sorry, I am going to ask questions which for most of you must look trivial, but I really do not know where to find the info you request. After a few unfruitful searches on the web, I decided to ask you directly.
example
longer
example
here
Nextcloud version (eg, 20.0.5): I know where to find this one: Settings - Overview - Version
Operating system and version (eg, Ubuntu 20.04): Where can it be found?
Apache or nginx version (eg, Apache 2.4.25): Where can it be found?
PHP version (eg, 7.4): Where can it be found?
The output of your Nextcloud log in Admin > Logging: Where can it be found?
PASTE HERE
The output of your config.php file in /path/to/nextcloud (make sure you remove any identifiable information!): Where can it be found? Could you give a list of what info is considered to be identifiable?
PASTE HERE
PASTE HERE
PASTE HERE
Output errors in nextcloud.log in /var/www/ or as admin user in top right menu, filtering for errors.
**Can you please explain more in detail how this is performed?**
Use a pastebin service if necessary.
**How does one use a pastebin service? Any suggestions on which to use and how to install it?**
PASTE HERE
this is basic knowledge for a website admin and not really nextcloud related. you should familiarize yourself with your OS (operating system) and shell.
there are many posible answers to your questions as it may differ depending on your installation type we must first know how you installed NC ex. link to a tutorial you followed.
basic shell commands:
list Operating System
cat /etc/lsb-release
cat /etc/os-release
php / apache versions
php -v
apache2 -v
program logs are usually in /var/log/
nc log is under /nc-data-dir/nextcloud.log
nc config.php in under /nc-install-dir/config/config.php
normal nc installation goes under /var/www/nextcloud but may vary upon installation.
Thanks @Vincent_Stans for the very detailed answer. We set up our server with Hetzner, and I suppose that we do not have access to Ubuntu shell with that set up.
The issue template is mainly about saving time for the volunteers, who are trying to help, because obviously it is very time consuming if you have to pull every detail out of someone’s nose. The more info you provide upfront, the better.
For people maintaining a manual installation, like Vincent already said, it can be expected that they know which OS they are using and how to do basic things like reading logs etc… In case you are using a web hosting platform or one of the various appliances out there, the template may not always fit a 100% and also not all the details may be necessary in order to solve a problem or to answer a specific question. Here you have to use some common sense. Rule of thumb: Provide as much information as you can, because in most cases it is better if you are providing too much information rather than too little.
However, in my experience, no one here will call you out on not using the issue template, if they see you have put some effort in your post and described your problem as good as you can, even if you left out a few things in the template. This answer is usually given for “low effort” posts, which often contain only one or two sentences, like: “XY doesn’t work, what should I do?”
…or even worse, people who leave all the placeholders of the template in their posts, even though they have only filled out one section of it. Then you have to find the relevant information in a wall of irrelevant text. Most of the time I just ignore those posts…
I would have loved to be able to give all the info needed, because providing more info would help solve the problem more quickly. But up to now, I was not able to access it (besides some more general info which I’ll provide).
Your post encourages me to go ahead and explain in another post the issue I am facing.
Still, if you do not mind, I will mark @Vincent_Stans answer as the solution, which would be the ideal scenario for the users who can access that info.
I just wanted to provide some additional and more general thoughts on the subject. Because for me, the decision to participate in a thread, was hardly ever based on whether someone has strictly adhered to the support template. The most important thing to me is that someone is willing to actively work towards a solution, rather than just demanding it. Of course, providing as much information as possible usually also helps with that…
