Nextcloud 11.0.1 (stable)
Ubuntu 16.04.03LTS
Apache/2.4.18 (Ubuntu)
PHP 7.0.22-0ubuntu0.16.04.1
Over the weekend I had to change my IP address scheme from 192.168.211.x to 192.168.11.x
I have already went into the config.php file and updated it to the latest IP address. But I can not get HTTPS to work.
When I go i get “site can not be reached” but when I do HTTP i can get in just fine.
I also tried running the following
user@nextcloud:~$ sudo nextcloud.enable-https lets-encrypt
got the following error.
sudo: nextcloud.enable-https: command not found
I am not sure what else to do.
Is this the first time you’ve seen this error? (Y/N):y
Fatal webdav Sabre\DAV\Exception\BadRequest: HTTP/1.1 400 expected filesize 1024000 got 176128
/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/File.php - line 104: OCA\DAV\Connector\Sabre\File->createFileChunked(Resource id #68)
/var/www/html/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php - line 137: OCA\DAV\Connector\Sabre\File->put(Resource id #68)
/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 1072: OCA\DAV\Connector\Sabre\Directory->createFile('20171204_122217...', Resource id #68)
/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 525: Sabre\DAV\Server->createFile('InstantUpload/C...', Resource id #68, NULL)
[internal function] Sabre\DAV\CorePlugin->httpPut(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/html/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105: call_user_func_array(Array, Array)
/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 479: Sabre\Event\EventEmitter->emit('method PUT', Array)
/var/www/html/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 254: Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/html/nextcloud/apps/dav/appinfo/v1/webdav.php - line 60: Sabre\DAV\Server->exec()
/var/www/html/nextcloud/remote.php - line 165: require_once('/var/www/html/n...')
{main}
'instanceid' => 'ocu6oy39v6e8',
'passwordsalt' => 'gKu18lAsvHhlLKPE7rV/Trr9tDUM+M',
'secret' => 'MD8sBlZKvYChbkG5duDcWY3NRcstdw/iUduJDOLzUhI23Urp',
0 => '192.168.11.227',
'datadirectory' => '/mnt/datastore_network',
'overwrite.cli.url' => 'http://192.168.11.227/nextcloud',
'version' => '11.0.1.2',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextclouduser',
'dbpassword' => 'nextcloud123',
'logtimezone' => 'UTC',
The output of your Apache/nginx/system log in /var/log/error.log
[Mon Feb 19 06:25:02.121538 2018] [mpm_prefork:notice] [pid 1006] AH00163: Apache/2.4.18 (Ubuntu) configured -- resuming normal operations
[Mon Feb 19 06:25:02.121574 2018] [core:notice] [pid 1006] AH00094: Command line: '/usr/sbin/apache2'
[Mon Feb 19 13:29:18.382358 2018] [mpm_prefork:notice] [pid 1027] AH00163: Apache/2.4.18 (Ubuntu) configured -- resuming normal operations
[Mon Feb 19 13:29:18.384677 2018] [core:notice] [pid 1027] AH00094: Command line: '/usr/sbin/apache2'
[Mon Feb 19 13:30:48.036871 2018] [mpm_prefork:notice] [pid 1027] AH00169: caught SIGTERM, shutting down
[Mon Feb 19 13:31:06.729858 2018] [mpm_prefork:notice] [pid 899] AH00163: Apache/2.4.18 (Ubuntu) configured -- resuming normal operations
[Mon Feb 19 13:31:06.742649 2018] [core:notice] [pid 899] AH00094: Command line: '/usr/sbin/apache2'
[Mon Feb 19 13:58:47.326330 2018] [:error] [pid 993] [client 192.168.11.226:37713] script '/var/www/html/status.php' not found or unable to stat
[Mon Feb 19 13:58:54.964039 2018] [:error] [pid 994] [client 192.168.11.226:46763] script '/var/www/html/status.php' not found or unable to stat
[Mon Feb 19 14:01:35.869463 2018] [:error] [pid 997] [client 192.168.11.226:55452] script '/var/www/html/status.php' not found or unable to stat
[Mon Feb 19 14:01:38.686746 2018] [:error] [pid 997] [client 192.168.11.226:55452] script '/var/www/html/status.php' not found or unable to stat
[Mon Feb 19 14:01:39.116991 2018] [:error] [pid 997] [client 192.168.11.226:55452] script '/var/www/html/status.php' not found or unable to stat
[Mon Feb 19 14:01:39.255813 2018] [:error] [pid 997] [client 192.168.11.226:55452] script '/var/www/html/status.php' not found or unable to stat
[Mon Feb 19 14:01:39.397822 2018] [:error] [pid 997] [client 192.168.11.226:55452] script '/var/www/html/status.php' not found or unable to stat
[Mon Feb 19 14:01:39.551103 2018] [:error] [pid 997] [client 192.168.11.226:55452] script '/var/www/html/status.php' not found or unable to stat
[Mon Feb 19 14:01:39.676507 2018] [:error] [pid 997] [client 192.168.11.226:55452] script '/var/www/html/status.php' not found or unable to stat
[Mon Feb 19 14:14:38.882264 2018] [mpm_prefork:notice] [pid 899] AH00169: caught SIGTERM, shutting down
[Mon Feb 19 14:14:59.251570 2018] [mpm_prefork:notice] [pid 903] AH00163: Apache/2.4.18 (Ubuntu) configured -- resuming normal operations
[Mon Feb 19 14:14:59.255747 2018] [core:notice] [pid 903] AH00094: Command line: '/usr/sbin/apache2'
i have also opened the ports on the FW on my ubuntu box.
