Call to undefined method OC\\DB\\QueryBuilder\\QueryBuilder::execute()
    • 33.0.3
    • Devuan Excalibur
    • Apache 2.4.67
    • None
    • 8.4.21 (FPM)
    • Yes
    • With Update to 33.0.3
    • ZIP Archive
    • Yes (mod_security)
Showing contacts on app “maps” will trigger a JavaScript error message with a 500 error as the root cause.
  1. Open up /apps/maps
  2. If the crash isn’t coming immediately, enable showing contacts on map
  3. A crash window should open
../nextcloud_data/nextcloud.log:{"reqId":"xyz","level":0,"time":"2026-05-16T19:13:13+02:00","remoteAddr":"1.2.3.4","user":"--","app":"serverDI","method":"GET","url":"/apps/maps/contacts","scriptName":"/index.php","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:140.0) Gecko/20100101 Firefox/140.0","version":"33.0.3.2","data":{"app":"serverDI"}}
../nextcloud_data/nextcloud.log:{"reqId":"xyz","level":0,"time":"2026-05-16T19:13:13+02:00","remoteAddr":"1.2.3.4","user":"foo","app":"serverDI","method":"GET","url":"/apps/maps/contacts","scriptName":"/index.php","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:140.0) Gecko/20100101 Firefox/140.0","version":"33.0.3.2","data":{"app":"serverDI"}}
../nextcloud_data/nextcloud.log:{"reqId":"xyz","level":0,"time":"2026-05-16T19:13:13+02:00","remoteAddr":"1.2.3.4","user":"foo","app":"maps","method":"GET","url":"/apps/maps/contacts","scriptName":"/index.php","message":"OCA\\Maps\\Controller\\ContactsController::getContacts uses the @NoAdminRequired annotation and should use the #[OCP\\AppFramework\\Http\\Attribute\\NoAdminRequired] attribute instead","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:140.0) Gecko/20100101 Firefox/140.0","version":"33.0.3.2","data":{"app":"maps"}}
../nextcloud_data/nextcloud.log:{"reqId":"xyz","level":0,"time":"2026-05-16T19:13:13+02:00","remoteAddr":"1.2.3.4","user":"foo","app":"maps","method":"GET","url":"/apps/maps/contacts","scriptName":"/index.php","message":"The requested alias \"UserId\" is deprecated. Please request \"userId\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:140.0) Gecko/20100101 Firefox/140.0","version":"33.0.3.2","data":{"app":"maps"}}
../nextcloud_data/nextcloud.log:{"reqId":"xyz","level":0,"time":"2026-05-16T19:13:13+02:00","remoteAddr":"1.2.3.4","user":"foo","app":"dav","method":"GET","url":"/apps/maps/contacts","scriptName":"/index.php","message":"The loading of lazy AppConfig values have been triggered by app \"dav\"","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:140.0) Gecko/20100101 Firefox/140.0","version":"33.0.3.2","exception":{"Exception":"RuntimeException","Message":"The loading of lazy AppConfig values have been triggered by app \"dav\"","Code":0,"Trace":[{"file":"/var/www/../htdocs/lib/private/AppConfig.php","line":492,"function":"loadConfig","class":"OC\\AppConfig","type":"->"},{"file":"/var/www/../htdocs/lib/private/AppConfig.php","line":427,"function":"getTypedValue","class":"OC\\AppConfig","type":"->"},{"file":"/var/www/../htdocs/apps/dav/lib/CardDAV/ContactsManager.php","line":50,"function":"getValueBool","class":"OC\\AppConfig","type":"->"},{"file":"/var/www/../htdocs/apps/dav/lib/CardDAV/ContactsManager.php","line":41,"function":"setupSystemContactsProvider","class":"OCA\\DAV\\CardDAV\\ContactsManager","type":"->"},{"file":"/var/www/../htdocs/apps/dav/lib/AppInfo/Application.php","line":264,"function":"setupContactsProvider","class":"OCA\\DAV\\CardDAV\\ContactsManager","type":"->"},{"file":"/var/www/../htdocs/apps/dav/lib/AppInfo/Application.php","line":252,"function":"setupContactsProvider","class":"OCA\\DAV\\AppInfo\\Application","type":"->"},{"file":"/var/www/../htdocs/lib/private/ContactsManager.php","line":194,"function":"{closure:OCA\\DAV\\AppInfo\\Application::registerContactsManager():249}","class":"OCA\\DAV\\AppInfo\\Application","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/../htdocs/lib/private/ContactsManager.php","line":35,"function":"loadAddressBooks","class":"OC\\ContactsManager","type":"->"},{"file":"/var/www/../htdocs/apps/maps/lib/Controller/ContactsController.php","line":142,"function":"search","class":"OC\\ContactsManager","type":"->"},{"file":"/var/www/../htdocs/lib/private/AppFramework/Http/Dispatcher.php","line":205,"function":"getContacts","class":"OCA\\Maps\\Controller\\ContactsController","type":"->"},{"file":"/var/www/../htdocs/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/../htdocs/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/../htdocs/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/../htdocs/lib/base.php","line":1155,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/../htdocs/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/../htdocs/lib/private/AppConfig.php","Line":1327,"message":"The loading of lazy AppConfig values have been triggered by app \"dav\"","exception":"{\"class\":\"RuntimeException\",\"message\":\"The loading of lazy AppConfig values have been triggered by app \\\"dav\\\"\",\"code\":0,\"file\":\"/var/www/../htdocs/lib/private/AppConfig.php:1327\",\"trace\":\"#0 /var/www/../htdocs/lib/private/AppConfig.php(492): OC\\AppConfig->loadConfig()\\n#1 /var/www/../htdocs/lib/private/AppConfig.php(427): OC\\AppConfig->getTypedValue()\\n#2 /var/www/../htdocs/apps/dav/lib/CardDAV/ContactsManager.php(50): OC\\AppConfig->getValueBool()\\n#3 /var/www/../htdocs/apps/dav/lib/CardDAV/ContactsManager.php(41): OCA\\DAV\\CardDAV\\ContactsManager->setupSystemContactsProvider()\\n#4 /var/www/../htdocs/apps/dav/lib/AppInfo/Application.php(264): OCA\\DAV\\CardDAV\\ContactsManager->setupContactsProvider()\\n#5 /var/www/../htdocs/apps/dav/lib/AppInfo/Application.php(252): OCA\\DAV\\AppInfo\\Application->setupContactsProvider()\\n#6 /var/www/../htdocs/lib/private/ContactsManager.php(194): OCA\\DAV\\AppInfo\\Application->{closure:OCA\\DAV\\AppInfo\\Application::registerContactsManager():249}()\\n#7 /var/www/../htdocs/lib/private/ContactsManager.php(35): OC\\ContactsManager->loadAddressBooks()\\n#8 /var/www/../htdocs/apps/maps/lib/Controller/ContactsController.php(142): OC\\ContactsManager->search()\\n#9 /var/www/../htdocs/lib/private/AppFramework/Http/Dispatcher.php(205): OCA\\Maps\\Controller\\ContactsController->getContacts()\\n#10 /var/www/../htdocs/lib/private/AppFramework/Http/Dispatcher.php(118): OC\\AppFramework\\Http\\Dispatcher->executeController()\\n#11 /var/www/../htdocs/lib/private/AppFramework/App.php(153): OC\\AppFramework\\Http\\Dispatcher->dispatch()\\n#12 /var/www/../htdocs/lib/private/Route/Router.php(321): OC\\AppFramework\\App::main()\\n#13 /var/www/../htdocs/lib/base.php(1155): OC\\Route\\Router->match()\\n#14 /var/www/../htdocs/index.php(25): OC::handleRequest()\\n#15 {main}\"}","CustomMessage":"The loading of lazy AppConfig values have been triggered by app \"dav\""}}
../nextcloud_data/nextcloud.log:{"reqId":"xyz","level":3,"time":"2026-05-16T19:13:13+02:00","remoteAddr":"1.2.3.4","user":"foo","app":"index","method":"GET","url":"/apps/maps/contacts","scriptName":"/index.php","message":"Call to undefined method OC\\DB\\QueryBuilder\\QueryBuilder::execute() in file '/var/www/../htdocs/apps/maps/lib/Service/AddressService.php' line 84","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:140.0) Gecko/20100101 Firefox/140.0","version":"33.0.3.2","exception":{"Exception":"Exception","Message":"Call to undefined method OC\\DB\\QueryBuilder\\QueryBuilder::execute() in file '/var/www/../htdocs/apps/maps/lib/Service/AddressService.php' line 84","Code":0,"Trace":[{"file":"/var/www/../htdocs/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/../htdocs/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/../htdocs/lib/base.php","line":1155,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/../htdocs/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/../htdocs/lib/private/AppFramework/Http/Dispatcher.php","Line":150,"Previous":{"Exception":"Error","Message":"Call to undefined method OC\\DB\\QueryBuilder\\QueryBuilder::execute()","Code":0,"Trace":[{"file":"/var/www/../htdocs/apps/maps/lib/Service/AddressService.php","line":64,"function":"lookupAddress","class":"OCA\\Maps\\Service\\AddressService","type":"->"},{"file":"/var/www/../htdocs/apps/maps/lib/Controller/ContactsController.php","line":206,"function":"addressToGeo","class":"OCA\\Maps\\Service\\AddressService","type":"->"},{"file":"/var/www/../htdocs/lib/private/AppFramework/Http/Dispatcher.php","line":205,"function":"getContacts","class":"OCA\\Maps\\Controller\\ContactsController","type":"->"},{"file":"/var/www/../htdocs/lib/private/AppFramework/Http/Dispatcher.php","line":118,"function":"executeController","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/../htdocs/lib/private/AppFramework/App.php","line":153,"function":"dispatch","class":"OC\\AppFramework\\Http\\Dispatcher","type":"->"},{"file":"/var/www/../htdocs/lib/private/Route/Router.php","line":321,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/../htdocs/lib/base.php","line":1155,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/../htdocs/index.php","line":25,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/../htdocs/apps/maps/lib/Service/AddressService.php","Line":84},"message":"Call to undefined method OC\\DB\\QueryBuilder\\QueryBuilder::execute() in file '/var/www/../htdocs/apps/maps/lib/Service/AddressService.php' line 84","exception":"{\"class\":\"Exception\",\"message\":\"Call to undefined method OC\\DB\\QueryBuilder\\QueryBuilder::execute() in file '/var/www/../htdocs/apps/maps/lib/Service/AddressService.php' line 84\",\"code\":0,\"file\":\"/var/www/../htdocs/lib/private/AppFramework/Http/Dispatcher.php:150\",\"trace\":\"#0 /var/www/../htdocs/lib/private/AppFramework/App.php(153): OC\\AppFramework\\Http\\Dispatcher->dispatch()\\n#1 /var/www/../htdocs/lib/private/Route/Router.php(321): OC\\AppFramework\\App::main()\\n#2 /var/www/../htdocs/lib/base.php(1155): OC\\Route\\Router->match()\\n#3 /var/www/../htdocs/index.php(25): OC::handleRequest()\\n#4 {main}\",\"previous\":{\"class\":\"Error\",\"message\":\"Call to undefined method OC\\DB\\QueryBuilder\\QueryBuilder::execute()\",\"code\":0,\"file\":\"/var/www/../htdocs/apps/maps/lib/Service/AddressService.php:84\",\"trace\":\"#0 /var/www/../htdocs/apps/maps/lib/Service/AddressService.php(64): OCA\\Maps\\Service\\AddressService->lookupAddress()\\n#1 /var/www/../htdocs/apps/maps/lib/Controller/ContactsController.php(206): OCA\\Maps\\Service\\AddressService->addressToGeo()\\n#2 /var/www/../htdocs/lib/private/AppFramework/Http/Dispatcher.php(205): OCA\\Maps\\Controller\\ContactsController->getContacts()\\n#3 /var/www/../htdocs/lib/private/AppFramework/Http/Dispatcher.php(118): OC\\AppFramework\\Http\\Dispatcher->executeController()\\n#4 /var/www/../htdocs/lib/private/AppFramework/App.php(153): OC\\AppFramework\\Http\\Dispatcher->dispatch()\\n#5 /var/www/../htdocs/lib/private/Route/Router.php(321): OC\\AppFramework\\App::main()\\n#6 /var/www/../htdocs/lib/base.php(1155): OC\\Route\\Router->match()\\n#7 /var/www/../htdocs/index.php(25): OC::handleRequest()\\n#8 {main}\"}}","CustomMessage":"Call to undefined method OC\\DB\\QueryBuilder\\QueryBuilder::execute() in file '/var/www/../htdocs/apps/maps/lib/Service/AddressService.php' line 84"}}
../nextcloud_data/nextcloud.log:{"reqId":"xyz","level":0,"time":"2026-05-16T19:13:13+02:00","remoteAddr":"1.2.3.4","user":"--","app":"serverDI","method":"GET","url":"/apps/theming/img/core/filetypes/image.svg?v=2","scriptName":"/index.php","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:140.0) Gecko/20100101 Firefox/140.0","version":"33.0.3.2","data":{"app":"serverDI"}}
../nextcloud_data/nextcloud.log:{"reqId":"xyz","level":0,"time":"2026-05-16T19:13:14+02:00","remoteAddr":"1.2.3.4","user":"foo","app":"serverDI","method":"GET","url":"/apps/theming/img/core/filetypes/image.svg?v=2","scriptName":"/index.php","message":"The requested alias \"OCP\\IServerContainer\" is deprecated. Please request \"Psr\\Container\\ContainerInterface\" directly. This alias will be removed in a future Nextcloud version.","userAgent":"Mozilla/5.0 (X11; Linux x86_64; rv:140.0) Gecko/20100101 Firefox/140.0","version":"33.0.3.2","data":{"app":"serverDI"}}
Not relevant, is server-side problem.
No relevant lines (to old, other vhosts)
            "cloud.mxchange.org"
        "overwrite.cli.url": "https:\/\/cloud.mxchange.org",
        "default_phone_region": "DE",
        "dbtype": "mysql",
        "debug": false,
        "version": "33.0.3.2",
        "mail_smtpmode": "sendmail",
        "trashbin_retention_obligation": "auto",
        "versions_retention_obligation": "auto",
        "config_is_read_only": false,
        "cipher": "AES-256-CFB",
        "activity_expire_days": 365,
        "mail_smtpauthtype": "PLAIN",
        "mail_smtpauth": 1,
        "mail_smtpport": "25",
        "singleuser": false,
        "data-fingerprint": "f7241e4abb9d6a3947844a90617df6f5",
        "enable_avatars": true,
        "allow_user_to_change_display_name": true,
        "session_keepalive": true,
        "updatechecker": true,
        "has_internet_connection": true,
        "check_for_working_webdav": true,
        "check_for_working_wellknown_setup": true,
        "check_for_working_htaccess": true,
        "logtimezone": "Europe\/Berlin",
        "loglevel": 0,
        "log_type": "file",
        "log_rotate_size": 10485760,
        "htaccess.RewriteBase": "\/",
        "upgrade.disable-web": true,
        "theme": "",
        "encryption.legacy_format_support": false,
        "auth.bruteforce.protection.enabled": false,
        "twofactor_enforced": false,
        "bulkupload.enabled": false,
            "admin"
        "app_install_overwrite": {
            "0": "files_downloadactivity",
            "1": "audioplayer",
            "2": "bookmarks",
            "4": "calendar",
            "5": "camerarawpreviews",
            "6": "checksum",
            "7": "circles",
            "8": "contacts",
            "9": "deck",
            "10": "files_ebookreader",
            "11": "video_converter",
            "12": "twofactor_totp",
            "13": "impersonate",
            "14": "gallery",
            "15": "mail",
            "16": "files_automatedtagging",
            "18": "files_texteditor",
            "19": "groupquota",
            "20": "maps",
            "21": "mood",
            "22": "event_update_notification",
            "23": "sharerenamer",
            "24": "socialsharing_email",
            "25": "twofactor_admin",
            "26": "twofactor_nextcloud_notification",
            "27": "socialsharing_diaspora",
            "28": "quota_warning",
            "29": "ojsxc",
            "30": "keeporsweep",
            "31": "metadata",
            "32": "dicomviewer",
            "34": "telephoneprovider",
            "35": "duplicatefinder",
            "36": "social",
            "37": "solitaire",
            "38": "wordfind"
        "mysql.utf8mb4": true,
        "mail_sendmailmode": "smtp"
  - activity: 6.0.0
  - admin_audit: 1.23.0
  - app_api: 33.0.0
  - audioplayer: 3.8.0
  - bookmarks: 16.1.4
  - bruteforcesettings: 6.0.0
  - calendar: 6.4.0
  - circles: 33.0.0
  - cloud_federation_api: 1.17.0
  - comments: 1.23.0
  - contacts: 8.4.5
  - contactsinteraction: 1.14.1
  - dav: 1.36.0
  - deck: 1.17.1
  - dicomviewer: 2.3.2
  - encryption: 2.21.0
  - event_update_notification: 2.8.0
  - federatedfilesharing: 1.23.0
  - files: 2.5.0
  - files_downloadlimit: 5.1.0
  - files_pdfviewer: 6.0.0
  - files_reminders: 1.6.0
  - files_sharing: 1.25.2
  - files_texteditor: 2.15.1
  - files_trashbin: 1.23.0
  - files_versions: 1.26.0
  - firstrunwizard: 6.0.0
  - groupquota: 0.2.4
  - impersonate: 4.0.0
  - integration_tmdb: 3.1.0
  - logreader: 6.0.0
  - lookup_server_connector: 1.21.0
  - mail: 5.7.15
  - maps: 1.6.0
  - metadata: 0.23.0
  - notes: 5.0.0
  - notifications: 6.0.0
  - oauth2: 1.21.0
  - oidc: 1.16.6
  - password_policy: 5.0.0
  - passwords: 2026.5.20
  - photos: 6.0.0
  - previewgenerator: 5.13.0
  - privacy: 5.0.0
  - profile: 1.2.0
  - provisioning_api: 1.23.0
  - quota_warning: 1.23.0
  - related_resources: 4.0.0
  - serverinfo: 5.0.0
  - settings: 1.16.0
  - sharebymail: 1.23.0
  - sharerenamer: 3.5.0
  - socialsharing_email: 4.1.0
  - solitaire: 1.0.0
  - survey_client: 5.0.0
  - suspicious_login: 11.0.0
  - systemtags: 1.23.0
  - text: 7.0.1
  - theming: 2.8.0
  - twofactor_admin: 4.11.1
  - twofactor_backupcodes: 1.22.0
  - twofactor_email: 3.0.10
  - twofactor_nextcloud_notification: 7.0.0
  - twofactor_totp: 15.0.0
  - updatenotification: 1.23.0
  - user_status: 1.13.0
  - viewer: 6.0.0
  - weather_status: 1.13.0
  - webhook_listeners: 1.5.0
  - wordfind: 1.4.2
  - workflowengine: 2.15.0
  - dashboard: 7.13.0 (installed 7.0.0)
  - duplicatefinder: 1.7.3 (installed 1.7.3)
  - federation: 1.23.0 (installed 1.22.0)
  - files_automatedtagging: 4.0.0 (installed 4.0.0)
  - files_downloadactivity: 1.18.1 (installed 1.18.1)
  - files_ebookreader: 0.0.1 (installed 0.0.1)
  - files_external: 1.25.1
  - flow_notifications: 4.0.0 (installed 4.0.0)
  - nextcloud_announcements: 5.0.0 (installed 1.14.0)
  - recommendations: 6.0.0 (installed 0.8.0)
  - support: 5.0.0 (installed 1.8.0)
  - testing: 1.23.0
  - user_ldap: 1.24.0
Looks like mapsis unmaintained ATM? So disabling it is the only “solution” (better fix it, of course).
You have quite a few apps force enabled so they’re bypassing compatibility checks. maps is one of them.
Looks like maps is unmaintained ATM? So disabling it is the only “solution” (better fix it, of course).
It’s getting updates within the code tree made, but I think the release owner(s) are busy. Not a repo I normally do much in, but I’ll poke around and see if I can nudge it forward a bit.
Thank you for wanting to forward this issue to them. Maybe it is a wake-up call to them? And can you please tell me how I have those apps not bypassed for compatibility check?
The issue seem to be fixed in latest master code. They properly invoke executeQuery() there.
Any apps listed in app_install_overwrite. Basically anything you’ve ever force enabled in the past.
Uff, that includes contacts, calendar, twofactor_* which are apps that I really would miss. I have now just cleared that array in my configuration file,
