on NextCloud 24.0.7, when I visit Calendar’s homepage from a browser
/apps/calendar/
I get redirect to the default calendar view, that it used to be dayGridMonth
/apps/calendar/dayGridMonth/now
somehow this default is changed, now visiting
/apps/calendar/
I get redirected to
/apps/calendar/timeGridDay/now
This is happening only for my NC user, I have checked with a colleague, and he is still on the dayGridMonth
default.
It seems that the change happened after accessing calendar from Firefox Android.
Now every time I visit
/apps/calendar/
I get redirected to
no matter the browser I use.
If I manually set the url to
this is not persisted.
So how to change Calendar’s default view to dayGridMonth
