Hello
Nextcloud version : 23.0.5-fpm-alpine
(dockerized)
Operating system and version : Alpine 3.16
Apache or nginx version : NginX 1.22
for reverse proxy and NginX 1.22
for the web server
PHP version (eg, 7.4): replace me
Since a re-installation of my Nextcloud, when I want to synchronize my calendar with my Android phone and caldav, I get this error : Token is not valid: Token does not exist
Thanks.
- Just sync my calendar with OpenSync (Android app)
"reqId": "071iUaW8VOh5JzXEl6aj",
"level": 0,
"time": "2022-06-19T20:51:04+00:00",
"remoteAddr": "172.18.0.1",
"user": "--",
"app": "no app in context",
"method": "PROPFIND",
"url": "/remote.php/dav/principals/users/imbrechts.kevin/",
"message": "Token is not valid: Token does not exist",
"userAgent": "OpenSync/1.5.0.3-ose (2017/04/18; dav4android; okhttp3) Android/11",
"version": "23.0.5.1",
"exception": {
"Exception": "OC\\Authentication\\Exceptions\\InvalidTokenException",
"Message": "Token does not exist",
"Code": 0,
"Trace": [{
"file": "/var/www/html/lib/private/Authentication/Token/Manager.php",
"line": 150,
"function": "getToken",
"class": "OC\\Authentication\\Token\\DefaultTokenProvider",
"type": "->",
"args": ["*** sensitive parameters replaced ***"]
"file": "/var/www/html/lib/private/User/Session.php",
"line": 531,
"class": "OC\\Authentication\\Token\\Manager",
"type": "->",
"line": 447,
"function": "isTokenPassword",
"class": "OC\\User\\Session",
"type": "->",
"file": "/var/www/html/apps/dav/lib/Connector/Sabre/Auth.php",
"line": 129,
"function": "logClientIn",
"type": "->",
"file": "/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php",
"line": 103,
"function": "validateUserPass",
"class": "OCA\\DAV\\Connector\\Sabre\\Auth",
"type": "->",
"line": 252,
"function": "check",
"class": "Sabre\\DAV\\Auth\\Backend\\AbstractBasic",
"type": "->",
"args": [{
"__class__": "Sabre\\HTTP\\Request"
"__class__": "Sabre\\HTTP\\Response"
"line": 154,
"function": "auth",
"type": "->",
"args": [{
"file": "/var/www/html/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php",
"line": 182,
"type": "->",
"args": [{
"line": 137,
"class": "Sabre\\DAV\\Auth\\Plugin",
"type": "->",
"args": [{
"file": "/var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php",
"line": 89,
"function": "beforeMethod",
"type": "->",
"args": [{
"file": "/var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php",
"line": 456,
"function": "emit",
"class": "Sabre\\DAV\\Server",
"type": "->",
"args": ["beforeMethod:PROPFIND", [{
"line": 253,
"function": "invokeMethod",
"type": "->",
"args": [{
"line": 321,
"function": "start",
"type": "->",
"args": []
"file": "/var/www/html/apps/dav/lib/Server.php",
"line": 339,
"function": "exec",
"type": "->",
"args": []
"file": "/var/www/html/apps/dav/appinfo/v2/remote.php",
"line": 35,
"function": "exec",
"class": "OCA\\DAV\\Server",
"type": "->",
"args": []
"file": "/var/www/html/remote.php",
"line": 166,
"args": ["/var/www/html/apps/dav/appinfo/v2/remote.php"],
"function": "require_once"
"File": "/var/www/html/lib/private/Authentication/Token/DefaultTokenProvider.php",
"Line": 170,
"Previous": {
"Exception": "OCP\\AppFramework\\Db\\DoesNotExistException",
"Message": "token does not exist",
"Code": 0,
"Trace": [{
"file": "/var/www/html/lib/private/Authentication/Token/DefaultTokenProvider.php",
"line": 168,
"class": "OC\\Authentication\\Token\\DefaultTokenMapper",
"type": "->",
"line": 150,
"type": "->",
"line": 531,
"type": "->",
"line": 447,
"type": "->",
"line": 129,
"type": "->",
"line": 103,
"type": "->",
"line": 252,
"type": "->",
"args": [{
"line": 154,
"function": "auth",
"type": "->",
"args": [{
"line": 182,
"type": "->",
"args": [{
"line": 137,
"type": "->",
"args": [{
"line": 89,
"type": "->",
"args": [{
"line": 456,
"function": "emit",
"type": "->",
"line": 253,
"type": "->",
"args": [{
"line": 321,
"type": "->",
"args": []
"line": 339,
"function": "exec",
"type": "->",
"args": []
"line": 35,
"function": "exec",
"type": "->",
"args": []
"line": 166,
"File": "/var/www/html/lib/private/Authentication/Token/DefaultTokenMapper.php",
"Line": 111
"CustomMessage": "Token is not valid: Token does not exist"
