Nextcloud version (eg, 20.0.5): 22.2.3snap1
Operating system and version (eg, Ubuntu 20.04): Ubuntu 20.04.3 LTS
Apache or nginx version (eg, Apache 2.4.25): apache behind nginx reverse proxy
PHP version (eg, 7.4): don't know
I can’t get taks to sync to Reminders.app on macOS Big Sur (11.6) using CalDAV, however:
- Calendar events do sync
- CalDAV does work for both calendar & tasks on iOS14
- It’s not a certificate issue (I’m using letsencrypt, AND see points 1. and 2. above)
- It’s not the known little snitch / Big Sur 11.0 error - I have the same issue booting in safe mode.
Furthermore, the macOS client (showing up as macOS/11.6.1 (20G224) CalendarAgent/954
) seems to PROPFIND
the same resource as iOS (/remote.php/dav/principals/users/USERNAME/
), but then fails and tries other resources using a different useragent string (`iOS/11.6.1 (20G224) remindd/1.0). See access.log below.
I hope somebody can help me and has some idea as to what’s going on! It’s driving me nuts
I’d really like to use nextcloud for my personal notes etc. to own my data a bit more.
on Nextcloud:
- Install nextcloud Calendar & Tasks apps
- Go to Calendar app > Settings & Import > Copy iOS/MacOS CalDAV address (=https://FQDN/remote.php/dav/principals/users/USERNAME/)
on macOS:
- configure new CalDAV account as ‘Advanced’ account type, username: USERNAME, password: password, server address: https://FQDN/, server path: /remote.php/dav/principals/users/USERNAME/, port 443, Use SSL enabled;
- After adding, ‘Use with Calendar’ is ticked, ‘Use with Reminders’ is not
- Calendar events sync, but Tasks/Reminders do not
on iOS:
- Add the account using the same settings as on macOS.
- After adding, both ‘Use with Calendar’ and ‘Use with Reminders’ are ticked
- Both Calendar events & Tasks/reminders sync
no logging shown
When I enable the account to macOS I get:
ipv4.macos - USERNAME [19/Dec/2021:21:52:58 +0100] "PROPFIND /remote.php/dav/calendars/USERNAME/ HTTP/1.1" 207 1428 "-" "macOS/11.6.1 (20G224) CalendarAgent/954"
ipv4.macos - USERNAME [19/Dec/2021:21:52:59 +0100] "PROPFIND /remote.php/dav/calendars/USERNAME/inbox/ HTTP/1.1" 207 260 "-" "macOS/11.6.1 (20G224) CalendarAgent/954"
ipv4.macos - USERNAME [19/Dec/2021:21:52:59 +0100] "REPORT /remote.php/dav/principals/users/USERNAME/ HTTP/1.1" 207 565 "-" "macOS/11.6.1 (20G224) CalendarAgent/954"
ipv4.macos - - [19/Dec/2021:21:53:00 +0100] "PROPFIND /.well-known/caldav HTTP/1.1" 301 257 "-" "iOS/11.6.1 (20G224) remindd/1.0"
ipv4.macos - - [19/Dec/2021:21:53:00 +0100] "PROPFIND / HTTP/1.1" 405 0 "-" "iOS/11.6.1 (20G224) remindd/1.0"
ipv4.macos - - [19/Dec/2021:21:53:00 +0100] "PROPFIND /principals/ HTTP/1.1" 405 225 "-" "iOS/11.6.1 (20G224) remindd/1.0"
ipv4.macos - - [19/Dec/2021:21:53:00 +0100] "PROPFIND /calendar/dav/USERNAME/user/ HTTP/1.1" 405 225 "-" "iOS/11.6.1 (20G224) remindd/1.0"
ipv4.macos - - [19/Dec/2021:21:53:03 +0100] "PROPFIND /.well-known/caldav HTTP/1.1" 301 257 "-" "iOS/11.6.1 (20G224) remindd/1.0"
ipv4.macos - - [19/Dec/2021:21:53:04 +0100] "PROPFIND / HTTP/1.1" 405 0 "-" "iOS/11.6.1 (20G224) remindd/1.0"
ipv4.macos - - [19/Dec/2021:21:53:04 +0100] "PROPFIND /principals/ HTTP/1.1" 405 225 "-" "iOS/11.6.1 (20G224) remindd/1.0"
ipv4.macos - - [19/Dec/2021:21:53:04 +0100] "PROPFIND /calendar/dav/USERNAME/user/ HTTP/1.1" 405 225 "-" "iOS/11.6.1 (20G224) remindd/1.0"
when I enable the account on iOS I get:
ipv4.ios - - [19/Dec/2021:21:51:54 +0100] "PROPFIND /remote.php/dav/principals/users/USERNAME/ HTTP/1.1" 401 569 "-" "iOS/14.8.1 (18H107) remindd/1.0"
ipv4.ios - USERNAME [19/Dec/2021:21:51:54 +0100] "PROPFIND /remote.php/dav/principals/users/USERNAME/ HTTP/1.1" 207 537 "-" "iOS/14.8.1 (18H107) remindd/1.0"
ipv4.ios - USERNAME [19/Dec/2021:21:51:54 +0100] "OPTIONS /remote.php/dav/principals/users/USERNAME/ HTTP/1.1" 200 0 "-" "iOS/14.8.1 (18H107) remindd/1.0"
ipv4.ios - - [19/Dec/2021:21:51:54 +0100] "REPORT /remote.php/dav/principals/groups/ HTTP/1.1" 401 569 "-" "iOS/14.8.1 (18H107) remindd/1.0"
ipv4.ios - USERNAME [19/Dec/2021:21:51:55 +0100] "REPORT /remote.php/dav/principals/groups/ HTTP/1.1" 200 290 "-" "iOS/14.8.1 (18H107) remindd/1.0"
ipv4.ios - - [19/Dec/2021:21:51:55 +0100] "PROPFIND /remote.php/dav/calendars/USERNAME/ HTTP/1.1" 401 569 "-" "iOS/14.8.1 (18H107) remindd/1.0"
ipv4.ios - USERNAME [19/Dec/2021:21:51:55 +0100] "PROPFIND /remote.php/dav/calendars/USERNAME/ HTTP/1.1" 207 1428 "-" "iOS/14.8.1 (18H107) remindd/1.0"
ipv4.ios - USERNAME [19/Dec/2021:21:51:56 +0100] "PROPFIND /remote.php/dav/principals/users/USERNAME/ HTTP/1.1" 207 315 "-" "iOS/14.8.1 (18H107) remindd/1.0"
ipv4.ios - USERNAME [19/Dec/2021:21:51:57 +0100] "PROPFIND /remote.php/dav/calendars/USERNAME/personal/ HTTP/1.1" 207 295 "-" "iOS/14.8.1 (18H107) remindd/1.0"
ipv4.ios - USERNAME [19/Dec/2021:21:51:57 +0100] "PROPFIND /remote.php/dav/calendars/USERNAME/personal/ HTTP/1.1" 207 526 "-" "iOS/14.8.1 (18H107) remindd/1.0"
ipv4.ios - USERNAME [19/Dec/2021:21:51:57 +0100] "REPORT /remote.php/dav/calendars/USERNAME/personal/ HTTP/1.1" 207 2551 "-" "iOS/14.8.1 (18H107) remindd/1.0"
