I can’t get OSX and iOS Calendar and Contacts Apps running with Nextcloud in my Docker environment.
I’ve set up the following:
- Nextcloud is running inside a docker container using wonderfall/nextcloud
- The jwilder/nginx-proxy is running in front, set up with SSL
Everything works fine. I can access the webinterface and even if I run from console:
CURL -u myuser -X PROPFIND https://cloud.example.com/remote.php/dav/addressbooks/users/myuser/contacts/
it succeeds.
But trying to setup it up with OSX Calendar will cause
cloud.example.com 123.45.12.34 - - [28/Aug/2016:14:02:48 +0000] "PROPFIND /remote.php/dav/principals/users/myuser/ HTTP/1.1" 401 426 "-" "Mac+OS+X/10.11.6 (15G31) CalendarAgent/361.2"
I tried everything with changing the nginx config but the strange thing is that it works with curl!
EDIT 1: Okay, using ‘digest’ as authentication method results in the same logs.
