I’ve just upgraded to NC 21 and I’m getting error messages saying " Your web server is not properly set up to resolve “/.well-known/webfinger”. Further information can be found in the documentation." I’m also getting the same message for CalDAV, CardDAV, and Nodeinfo. I’ve searched the archives and Google for help, but haven’t been able to resolve the issue. Can anyone shed any light on the subject?
example
longer
example
here
Nextcloud version 21.0.0
Operating system and version Ubuntu 20.04
nginx version 1.19.7
PHP version 8.0.3
Is this the first time you’ve seen this error? Y
Debug files_sharing /appinfo/app.php is deprecated, use \OCP\AppFramework\Bootstrap\IBootstrap on the application class instead.
2021-03-07T02:56:01-0500
'instanceid' => 'ocaro7r930mk',
'passwordsalt' => 'BHVfJfqlcPFLlgq0MrT1SNxvT74j16',
'secret' => 'q+U6EmpeYxsp4k1Aluova+y/NlTFr1itL622WmA+UK1VP2ma',
0 => 'nextcloud.koalatyworks.com',
'datadirectory' => '/usr/share/nginx/nextcloud-data',
'version' => '21.0.0.18',
'overwrite.cli.url' => 'https://nextcloud.koalatyworks.com',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'redacted',
'dbpassword' => 'redacted',
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_from_address' => 'wizard',
'mail_domain' => 'koalatyworks.com',
'mail_smtphost' => 'grace.koalatyworks.com',
'mail_smtpport' => '587',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'theme' => '',
'loglevel' => 0,
'updater.secret' => '$2y$10$UThEKRzSpGr1GzkYOuiXbea9iJS5TkJMjuNxLafgVBmXC2sV1dow2',
The output of your nginx system log in /var/log/____
Not available
