Hi!
In the nextcloud .htaccess there is this line:
<FilesMatch "\.(css|js|svg|gif)$">
Header set Cache-Control "max-age=15778463"
</FilesMatch>
However there are other files served statically. For example /core/js/dist/maintenance.js.map
and other .map
files. Should they not be cached? Otherwise I think the .js.map
files should be added to the .htaccess
What about png and jpeg files that might be served too?
