[Bug]: External storage "Restrict to" multi-select does not grow with selected entries, chips overlap the next field
:warning: This issue respects the following points: :warning:
  • This is not a troubleshooting question, general support matter, or webserver/proxy problem, but likely a bug (if unsure, ask the Community Help Forum).
    This issue is not already reported on Github OR solved at the Community Help Forum (I’ve searched!).
    I’m using a maintained major version of Nextcloud Server and tested against the latest patch level. (Supported major versions and current patch levels).
    I agree to follow Nextcloud’s Code of Conduct.
    I’ve tried my best to provide clear reproduction steps that someone unfamiliar with this bug could use to reproduce it.
Bug description
In Administration settings → External storage, in the “Edit storage” dialog, the “Restrict to” multi-select does not expand vertically when several users/groups are selected. The selected entries (chips) overflow the field and are drawn on top of the next field (the “External storage” backend select).
Browser zoom does not change the behaviour.
Reproduced on two different rendering engines (Firefox/Gecko and Brave/Chromium), so it does not look browser-specific.
The font in use is Inter, as expected.
Steps to reproduce
Go to Administration settings → External storage
Edit an existing mount (SFTP backend in my case)
In “Restrict to”, add several entries (1 group + 4 users here)
The last chips overflow the field and overlap the “External storage” select below
Expected behavior
The “Restrict to” field grows to fit its entries (or becomes scrollable) and does not overlap other fields of the dialog.
Nextcloud Server version
35
Operating system
Debian/Ubuntu
PHP engine version
PHP 8.4
Web server
Apache (supported)
Database engine version
PostgreSQL
Is this bug present after an update or on a fresh install?
Updated from a MINOR version (ex. 32.0.1 to 32.0.2)
Are you using the Nextcloud Server Encryption module?
Encryption is Disabled
What user-backends are you using?
  • Default user-backend (database)
    LDAP/ Active Directory
    SSO - SAML
    Other
Configuration report
        "redis": {
            "port": 6379
        "overwritehost": "***REMOVED SENSITIVE VALUE***",
        "overwriteprotocol": "https",
            "localhost",
        "dbtype": "pgsql",
        "version": "35.0.1.1",
        "overwrite.cli.url": "***REMOVED SENSITIVE VALUE***",
        "dbport": "",
        "loglevel": "2",
        "log_type": "file",
        "logfile": "\/var\/www\/html\/nextcloud\/data\/nextcloud.log",
        "log_rotate_size": "10485760",
        "log.condition": {
            "apps": [
                "admin_audit"
        "preview_max_x": "2048",
        "preview_max_y": "2048",
        "jpeg_quality": "60",
        "enabledPreviewProviders": {
            "1": "OC\\Preview\\Image",
            "2": "OC\\Preview\\MarkDown",
            "3": "OC\\Preview\\MP3",
            "4": "OC\\Preview\\TXT",
            "6": "OC\\Preview\\Movie"
        "enable_previews": true,
        "upgrade.disable-web": true,
        "mail_smtpmode": "smtp",
        "activity_expire_days": "30",
        "share_folder": "\/Shared",
        "tempdirectory": "\/var\/www\/html\/nextcloud\/data",
        "htaccess.RewriteBase": "\/",
        "defaultapp": "apporder",
        "mail_sendmailmode": "smtp",
        "mail_smtpport": "25",
        "default_phone_region": "FR",
        "forbidden_filename_characters": [
        "forbidden_filename_extensions": [
            ".filepart",
            ".part"
List of activated Apps
  - activity: 8.0.0
  - admin_audit: 2.0.0-dev.0
  - app_api: 35.0.0
  - appstore: 2.0.0-dev.0
  - bruteforcesettings: 8.0.0
  - circles: 35.0.0
  - cloud_federation_api: 2.0.0-dev.0
  - comments: 2.0.0-dev.0
  - contacts: 8.9.0
  - contactsinteraction: 2.0.0-dev.0
  - dashboard: 8.0.0-dev.0
  - dav: 2.0.0-dev.1
  - federatedfilesharing: 2.0.0-dev.1
  - federation: 2.0.0-dev.0
  - files: 3.0.0-dev.0
  - files_downloadlimit: 5.3.0
  - files_external: 2.0.0-dev.0
  - files_lock: 35.0.0
  - files_pdfviewer: 8.0.0
  - files_reminders: 2.0.0-dev.0
  - files_sharing: 2.0.0-dev.1
  - files_trashbin: 2.0.0-dev.0
  - files_versions: 2.0.0-dev.0
  - firstrunwizard: 8.0.0
  - forms: 5.4.0
  - groupfolders: 23.0.1
  - logreader: 8.0.0
  - lookup_server_connector: 2.0.0-dev.0
  - nextcloud_announcements: 7.0.0
  - notifications: 8.0.0
  - notify_push: 1.4.1
  - oauth2: 2.0.0-dev.0
  - office: 1.1.0
  - password_policy: 7.0.0
  - photos: 8.0.0
  - privacy: 7.0.0
  - profile: 2.0.0-dev.0
  - provisioning_api: 2.0.0-dev.0
  - recommendations: 8.0.0
  - related_resources: 6.0.0
  - richdocuments: 12.0.0
  - richdocumentscode: 26.4.402
  - serverinfo: 7.0.0
  - settings: 2.0.0-dev.0
  - sharebymail: 2.0.0-dev.0
  - sharing: 1.0.4
  - support: 7.0.0
  - survey_client: 7.0.0
  - systemtags: 2.0.0-dev.0
  - text: 9.0.0
  - theming: 3.0.0-dev.0
  - twofactor_backupcodes: 2.0.0-dev.0
  - updatenotification: 2.0.0-dev.0
  - user_ldap: 2.0.0-dev.0
  - user_status: 2.0.0-dev.0
  - viewer: 8.0.0
  - weather_status: 2.0.0-dev.0
  - webhook_listeners: 2.0.0-dev.0
  - workflowengine: 3.0.0-dev.0
  - encryption: 3.0.0-dev.0
  - files_mindmap: 0.0.33 (installed 0.0.33)
  - files_rightclick: 0.15.1 (installed 1.6.0)
  - suspicious_login: 13.0.0
  - twofactor_nextcloud_notification: 9.0.0
  - twofactor_totp: 17.1.0 (installed 7.0.0)
Nextcloud Signing status
Technical information
The following list covers which files have failed the integrity check. Please read
the previous linked documentation to learn more about the errors and how to fix
them.
Results
- files_mindmap
	- EXCEPTION
		- OC\IntegrityCheck\Exceptions\InvalidSignatureException
		- Certificate is not valid.
Raw output
Array
    [files_mindmap] => Array
            [EXCEPTION] => Array
                    [class] => OC\IntegrityCheck\Exceptions\InvalidSignatureException
                    [message] => Certificate is not valid.
Nextcloud Logs
Additional info
  • Browsers: Firefox 157 and Brave (Chromium) — same result
  • Client OS: Zorin OS 18, font in use: Inter
  • UI language: French (“Restreindre à” = “Restrict to”)
  • Upgrade path: 35.0.0 → 35.0.1
Possibly related:
