Well, I tought it was only the bruteforce attempts for blocking the uploads. I´ve checked now the logs and it seems for a few files, that they coulnd´t upload, because the Sambe makes a mistake:
> Sabre\DAV\Exception\NotFound: File with name SofortUpload/2016/12/IMG_20161214_195618.jpg could not be located
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 81: OCA\DAV\Connector\Sabre\ObjectTree->getNodeForPath('SofortUpload/20...')
[internal function] Sabre\DAV\CorePlugin->httpGet(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105: call_user_func_array(Array, Array)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 479: Sabre\Event\EventEmitter->emit('method GET', Array)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 253: Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response), false)
[internal function] Sabre\DAV\CorePlugin->httpHead(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 479: Sabre\Event\EventEmitter->emit('method HEAD', Array)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 254: Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/nextcloud/apps/dav/appinfo/v1/webdav.php - line 71: Sabre\DAV\Server->exec()
/var/www/nextcloud/remote.php - line 162: require_once('/var/www/nextcl...')
{main}
I got errors like this:
Sabre\DAV\Exception\BadRequest: expected filesize 1024000 got 425984
/var/www/nextcloud/apps/dav/lib/Connector/Sabre/File.php - line 105: OCA\DAV\Connector\Sabre\File->createFileChunked(Resource id #21)
/var/www/nextcloud/apps/dav/lib/Connector/Sabre/Directory.php - line 151: OCA\DAV\Connector\Sabre\File->put(Resource id #21)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 1096: OCA\DAV\Connector\Sabre\Directory->createFile(‘IMG_20161214_19…’, Resource id #21)
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/CorePlugin.php - line 525: Sabre\DAV\Server->createFile(‘SofortUpload/20…’, Resource id #21, NULL)
[internal function] Sabre\DAV\CorePlugin->httpPut(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 479: Sabre\Event\EventEmitter->emit(‘method PUT’, Array)
/var/www/nextcloud/remote.php - line 162: require_once(’/var/www/nextcl…’)
{main}
I´m using the android App Version 1.4.3 on the Huawei Y6 2017 (MYA-L41, Android 6.0) and i uploaded last night hundrets of files. But it fails many times, i retried many times but now a few files won´t be uploaded.
Over mobile network it is sometimes faster to upload and the upload ist mostly (not tested at all) without problems. In the wlan it says it has sometimes “Connection Problems”. How i said i just tested the mobile network just with 2-3 files, because I don´t want to waste my mobile traffic
I hope anybody has an idea whats wrong.
EDIT: My old smartphone (S3 Neo, Modded with TWRP, Android 6.0.1 was faster and better with uploads and it has got less Problems like the Huawei.
EDIT2: I watched now in the Pihole interfaces and I think I can referable the “Connection Problem” to the accumulation of heat(60-70°C, last evening even 80°C). Well, the Pi was claimed all night with uploads over the Webdav. But i think it doesn´t explain the error messages in the logs.
