Brute Force 192.168.1.1?
Have NC server (18.0.10) running in a virtualbox, ubuntu instance, and see in my logs many of the following,
[core] Info: Bruteforce attempt from “192.168.1.1” detected for action “login”.
PROPFIND /remote.php/webdav/Work/Brookhaven%202016%20NYS%20Supplement.docx
from 192.168.1.1 at 2020-10-31T23:16:46+00:00
The strange thing is the username that attempting to log in is an email address I use only in work.
So, Im wondering if someone figured my work email out (Not too difficult) and is flooding my server with login attempts.
Any suggestions what I should do ?
seams for a typical job for fail 2 ban.
Understood…
if the the attack is from 192.168.1.1 (through my router) is there any way to resolve the original IP ?
I don’t think this is an intrusion attempt (although fail2ban is always a good idea). You should duckduckgo the web for “PROPFIND /remote.php/webdav/” .
