I am installing nextcloud for the first time, on a VPS hosting account.
I tried the installer.php method and also with the zip file from the oficial nextcloud server.
I got it installed on a fresh blank DB with full permissions, assigned 512MB of memory to it and upped the execution times and file size limits.
Then i login for the first time, and this is what i get:
So i see only 3 options to install nextcloud: the web installer (done, no go), the archive file (same issue) and the VM appliance that i can not implement in a cPanel.
Also the first line of my original post starts with the current configuration for my server, CENTOS… i have no clue why you mentioned all that about Debian, or assumed i was using debian.
404 … yes i know those, so this is why i am asking if i am missing anything here like dependencies or any other extensions. I choose to install the extra applications (mail, calendar, video, etc) that is offered during the simple installation process.
There are other errors besides the 404 errors…
I repeat, this is a clean new vanilla installation on an empty new cpanel, with 512MB of memory assigned to it, on CENTOS, and using MariaDB.
Just checked… 51GB free…
I got no restrictions under this WHM… i assigned many resources for this specific instance so HDD space should not be an issue.
Thank you
I also did a search for “Linux” and there are lots of issues coming up in the results…
So you are suggesting i use a plain LAMP server and create the container for it without using cPanel? That would mean my whole VPS account which is managed with WHM is useless for nextcloud?
