Weve got an fresh installation with Nextcloud and Onlyoffice in Docker on the same Server.
It all runs perfect but weve got an big Problem.
The Language on Nextcloud is German. With all browsers weve got german to on Onlyoffice.
But in Google Chrome Desktop the Language in Onlyoffice is English.
i also contactet The Support from Onlyoffice they say: It seems the issue is in your Nextcloud config config.php, first three strings with errors indicate that.
The issue is: Error with Feature-Policy header: Unrecognized feature: ‘notifications’.
Error with Feature-Policy header: Unrecognized feature: ‘push’.
Error with Feature-Policy header: Unrecognized feature: ‘vibrate’.
config.php:
'passwordsalt' => '%%%',
'secret' => '%%%',
0 => 'localhost',
1 => '%%%',
'datadirectory' => '/var/nc_data',
'version' => '15.0.5.3',
'overwrite.cli.url' => '%%%',
'dbname' => '%%%',
'dbhost' => '%%%',
'dbuser' => '%%%',
'dbpassword' => '%%%',
'instanceid' => 'oc2i1on2voem',
'activity_expire_days' => 14,
'auth.bruteforce.protection.enabled' => 'true',
'blacklisted_files' =>
0 => '.htaccess',
1 => 'Thumbs.db',
2 => 'thumbs.db',
'cron_log' => true,
'enable_previews' => true,
'enabledPreviewProviders' =>
0 => 'OC\\Preview\\PNG',
1 => 'OC\\Preview\\JPEG',
2 => 'OC\\Preview\\GIF',
3 => 'OC\\Preview\\BMP',
4 => 'OC\\Preview\\XBitmap',
5 => 'OC\\Preview\\Movie',
6 => 'OC\\Preview\\PDF',
7 => 'OC\\Preview\\MP3',
8 => 'OC\\Preview\\TXT',
9 => 'OC\\Preview\\MarkDown',
'filesystem_check_changes' => 0,
'integrity.check.disabled' => false,
'knowledgebaseenabled' => false,
'logfile' => '/var/nc_data/nextcloud.log',
'loglevel' => 2,
'log_rotate_size' => 104857600,
'cron_log' => true,
'loglevel' => 2,
'preview_max_x' => 1024,
'preview_max_y' => 768,
'preview_max_scale_factor' => 1,
'redis' =>
'port' => 0,
'timeout' => 0.0,
'quota_include_external_storage' => false,
'share_folder' => '/Shares',
'skeletondirectory' => '',
'theme' => '',
'trashbin_retention_obligation' => 'auto, 7',
Please i need fast help.
We working already with this platform.
Thanks so much!
