what is the best way to reference files or folders when working together with other users on the same nc domain?
Using the internal link (like https://cloud.io/index.php/apps/files?dir=/Documents/Folder) doesn’t work, because it may be renamed in the other users workspace.
Using a share link (like https://cloud.io/index.php/s/Fmeek3QqNqt8na2) doen’t work neither because the file or folder ist opened in anonymous mode (asking for a nickname)
Is there a beter way than thes two?
Thankyou!
