No, that alone won’t be enough!
@kinhswch needs to install both the “Built-in CODE Server (ARM64)” and the “Nextcloud Office” app, just like I showed in the screenshots above.
If it still doesn’t work after installing both, then there’s likely another issue we haven’t identified yet.
Just to clarify: the Nextcloud Office app is what actually integrates the CODE server into the Nextcloud UI. Without it, you won’t be able to use the built-in server, so again, simply installing the CODE server by itself isn’t enough.
