I recently installed 2 instances of nextcloud with data on both nodes synced.
independently they work fine. but when I try to access them via haproxy node ip
I get 503 Gateway Time-out The server didn’t respond in time if I try to access via locally setup domain name. the locally set up domain name points to haproxy node ip 192.168.0.14
Also via haproxy I am having to sign in twice ! this is more of which is killing me.
also some
Nextcloud version (eg, 18.0.2): 20.0.1.1.1
Operating system and version (eg, Ubuntu 20.04): 18.04 /20.04
Apache or nginx version (eg, Apache 2.4.25): 2.4
PHP version (eg, 7.1): php 7.4
504 Gateway Time-out The server didn’t respond in time. when trying to access via haproxy
This is my haproxy config
$ cat /etc/haproxy/haproxy.cfg
global
log 127.0.0.1 local0 notice
maxconn 4096
chroot /var/lib/haproxy
user haproxy
group haproxy
daemon
defaults
log global
mode tcp
option tcplog
option dontlognull
timeout connect 25s
timeout client 25s
timeout server 25s
listen http-in
bind *:80
mode http
stats enable
server nc1 192.168.0.14 check
server nc2 192.168.0.15 check
but when I directly access each node it works fine.
