Backup with rsync in cron job ends up with an empty data directory
    Linux 6.18.22-i1-hp x86_64
    • Apache 2.4.
    • no idea how to check
    • 8.4.20
    • no
    • from the begining
    • manual installation
    • not that I would know
Summary of the issue you are facing
I have created a script to backup nextcloud. This script is planned to be started from a cron job. My installation is hosted at TELEKOM with an business contract on a virtual server. I do think I have troubles with the user rights.
When I start the script from an ssh connection to the server evertyhing went well. When I start the script via cron the script will be interrupted ba an fault. The scripte is nat allowed to copy the data directory. I think the user that is used by cron is not able to touch the data directory.
drwxrwx— 20 www-data www-data 4096 31. Mär 11:18 data
This are the rights at the data directory.
I have tried to start the rsync command directly with cron an end up with an empty data directory.
I fear to change the user rights of the data directory because of the data safety.
is ther a posibillity to find out the user of cron and add them to the user group of www-data to give cron the necessayr rights to the datat directory.
any other hint how I can overcoem this situation.
This is the script I’m rying to use for the backup
#!/bin/bash -e
#Das ist das Backup der Nextcloud Seite als script
0.Schritt Maintenance Mode ein
echo “Jetzt geht es los: $(date)”>/home/www/scripts/next.txt
cd /home/www/public_html/nextcloud
php occ maintenance:mode --on
1.Schritt Daten kopieren
rsync -avz --delete -b --backup-dir=/home/www/backupalt /home/www/public_html/nextcloud /home/www/backup
echo “Daten sind kopiert: $(date)”>>/home/www/scripts/next.txt
1.1 Schritt Maintenance Mode aus
php occ maintenance:mode --off
2.Schritt Datenbank backup anlegen
mysqldump -h mysqla.service -u HTO01FLQKVOF_3 -pJuqoaPpqWqU9ehWW HTO01FLQKVOF_3 > /home/www/datenbank/NEXTCLOUD.sql
echo “Datenbank Abzug ist erfolgt: $(date)”>>/home/www/scripts/next.txt
3.Schritt Datenbankkopie in das backup Verzeichnis kopieren
rsync -avz --delete -b --backup-dir=/home/www/backupalt /home/www/datenbank /home/www/backup
echo “Alles erledigt: $(date)”>>/home/www/scripts/next.txt
Steps to replicate it (hint: details matter!): Non is an continuous problem
Log entries Non
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
Do not change the Nextcloud folder permissions, it is a security risk! The problem with cron jobs is maybe due to two things:
Missing paths: Cron does not recognize standard commands. You can use absolute paths in the script (e.g., /usr/bin/php instead of php and /usr/bin/rsync instead of rsync).
Maybe wrong user: Use echo $(whoami) in the script to check whether the Cron job is actually running under your SSH user or is being started by the system as a restricted user.
rsyn -v -n --stats --progress should give you some more infos.
Maybe you show the whole script and the cron -l output?
Please let me know if this helps.
