Background Jobs not running successfully
    • 28.0.12
    • Ubuntu 22.04.5 LTS
    • Apache 2.4.52
    • n/a
    • 8.1.2
    • Yes
    • 20 days ago per the system Administration Overview
    • Bare Metal
[I have noticed hundreds of errors in my logs, almost all related to the background tasks being unable to run. Crontab runs the cron.php job every 10 minutes.]
  1. Running the cron.php job manually results in a similar error as well.
Manual cron invocation command: sudo -u www-data php /var/www/nextcloud/cron.php
Result of above manual invocation of cron.php
Error: Cannot call constructor in /var/www/nextcloud/apps/activity/lib/BackgroundJob/RemoteActivity.php:40
Stack trace:
#0 [internal function]: OCA\Activity\BackgroundJob\RemoteActivity->__construct()
#1 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(120): ReflectionClass->newInstanceArgs()
#2 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(128): OC\AppFramework\Utility\SimpleContainer->buildClass()
#3 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(146): OC\AppFramework\Utility\SimpleContainer->resolve()
#4 /var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php(470): OC\AppFramework\Utility\SimpleContainer->query()
#5 /var/www/nextcloud/lib/private/ServerContainer.php(155): OC\AppFramework\DependencyInjection\DIContainer->queryNoFallback()
#6 /var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php(64): OC\ServerContainer->query()
#7 /var/www/nextcloud/lib/public/Server.php(55): OC\AppFramework\Utility\SimpleContainer->get()
#8 /var/www/nextcloud/lib/private/BackgroundJob/JobList.php(325): OCP\Server::get()
#9 /var/www/nextcloud/lib/private/BackgroundJob/JobList.php(234): OC\BackgroundJob\JobList->buildJob()
#10 /var/www/nextcloud/cron.php(145): OC\BackgroundJob\JobList->getNext()
#11 {main}
{"reqId":"0J9Hpd6ot5q7GnZx6m1H","level":3,"time":"2024-12-13T23:45:01+00:00","remoteAddr":"","user":"--","app":"cron","method":"","url":"--","message":"Exception thrown: Error","userAgent":"--","version":"28.0.12.2","exception":{"Exception":"Error","Message":"Cannot call constructor","Code":0,"Trace":[{"function":"__construct","class":"OCA\\Activity\\BackgroundJob\\RemoteActivity","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":120,"function":"newInstanceArgs","class":"ReflectionClass","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":128,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":146,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":470,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/ServerContainer.php","line":155,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":64,"function":"query","class":"OC\\ServerContainer","type":"->"},{"file":"/var/www/nextcloud/lib/public/Server.php","line":55,"function":"get","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":325,"function":"get","class":"OCP\\Server","type":"::"},{"file":"/var/www/nextcloud/lib/private/BackgroundJob/JobList.php","line":234,"function":"buildJob","class":"OC\\BackgroundJob\\JobList","type":"->"},{"file":"/var/www/nextcloud/cron.php","line":145,"function":"getNext","class":"OC\\BackgroundJob\\JobList","type":"->"}],"File":"/var/www/nextcloud/apps/activity/lib/BackgroundJob/RemoteActivity.php","Line":40,"CustomMessage":"Exception thrown: Error"},"id":"675cc8404a949"}
        "supportedDatabases": [
            "mysql",
            "pgsql",
            "oci"
            "10.100.1.10",
            "10.100.1.11",
            "10.90.1.30",
            "cloud.***REMOVED SENSITIVE VALUE***.org"
        "overwrite.cli.url": "https:\/\/cloud.***REMOVED SENSITIVE VALUE***.org",
        "dbtype": "mysql",
        "version": "28.0.12.2",
        "ldapIgnoreNamingRules": false,
        "ldapUserCleanupInterval": 51,
        "lost_password_link": "disabled",
        "logtimezone": "UTC",
        "logfile": "\/var\/log\/nextcloud\/nextcloud.log",
        "filelocking.enabled": "true",
        "redis": {
            "port": 6379,
            "timeout": 0
        "loglevel": 1,
        "trashbin_retention_obligation": "auto",
        "versions_retention_obligation": "auto",
        "theme": "",
        "htaccess.RewriteBase": "\/",
        "mail_smtpmode": "smtp",
        "mail_smtpport": "25",
        "ldapProviderFactory": "\\OCA\\User_LDAP\\LDAPProviderFactory",
        "knowledgebaseenabled": false,
        "auth.bruteforce.protection.enabled": false,
        "mysql.utf8mb4": true,
        "log_rotate_size": 0,
        "default_phone_region": "US",
        "profile.enabled": false,
        "maintenance_window_start": 3
  • activity: 2.20.0
  • admin_audit: 1.18.0
  • cloud_federation_api: 1.11.0
  • comments: 1.18.0
  • dav: 1.29.2
  • deck: 1.12.6
  • federatedfilesharing: 1.18.0
  • federation: 1.18.0
  • files: 2.0.0
  • files_external: 1.20.0
  • files_pdfviewer: 2.9.0
  • files_reminders: 1.1.0
  • files_sharing: 1.20.0
  • files_trashbin: 1.18.0
  • files_versions: 1.21.0
  • firstrunwizard: 2.17.0
  • groupfolders: 16.0.12
  • impersonate: 1.15.0
  • logreader: 2.13.0
  • lookup_server_connector: 1.16.0
  • notifications: 2.16.0
  • oauth2: 1.16.4
  • onlyoffice: 9.5.0
  • photos: 2.4.0
  • provisioning_api: 1.18.0
  • quota_warning: 1.20.0
  • related_resources: 1.3.0
  • serverinfo: 1.18.0
  • settings: 1.10.1
  • sharelisting: 1.2.0
  • systemtags: 1.18.0
  • text: 3.9.2
  • theming: 2.3.0
  • twofactor_backupcodes: 1.17.0
  • twofactor_totp: 10.0.0-beta.2
  • updatenotification: 1.18.0
  • user_ldap: 1.19.0
  • user_saml: 6.4.1
  • user_usage_report: 1.12.1
  • viewer: 2.2.0
  • workflowengine: 2.10.0
  • apporder: 0.15.0 (installed 0.15.0)
  • bruteforcesettings: 2.8.0 (installed 1.6.0)
  • circles: 28.0.0 (installed 22.3.1)
  • contactsinteraction: 1.9.0 (installed 1.5.0)
  • dashboard: 7.8.0 (installed 7.0.0)
  • encryption: 2.16.0
  • files_rightclick: 0.15.1 (installed 1.6.0)
  • nextcloud_announcements: 1.17.0 (installed 1.1)
  • password_policy: 1.18.0 (installed 1.2.2)
  • privacy: 1.12.0 (installed 1.0.0)
  • recommendations: 2.0.0 (installed 0.4.0)
  • sharebymail: 1.18.0 (installed 1.8.0)
  • support: 1.11.1 (installed 1.7.0)
  • survey_client: 1.16.0 (installed 1.0.0)
  • suspicious_login: 6.0.0
  • user_status: 1.8.1 (installed 1.0.1)
  • weather_status: 1.8.0 (installed 1.0.0)
Thank you for any assistance or clues to help me fix this issue.
This was already fixed in >= 28.0.13.
Thank you JTR.
I will try to upgrade this weekend.
Does anyone know, since 28.0.13 was withdrawn, will upgrade.phar offer to upgrade to 28.0.14 or to 29.0.10?
I presume it will present 28.0.14.
