System - Pi3 running HypriotOS with official NextCloud docker container from docker hub.
Versions - NextCloudPi v0.59.0, image NextCloudPlus_04-29-18
Issue - normally I just leave the system to run and update itself stand-alone (nc-autoupdate-ncp and nc-update-nextcloud both enabled), but I came back from holiday to a non-functional system.
I can access the NextCloudPi panel, which reports a NextCloud check error and both Redis and Postfix services down (and the ports 80/443 closed, although they are actually open on the router and pointed to the pi).
If I try and update nextcloud (nc-update) that works, but if I try nc-update-nextcloud (to version 13.0.4 if I just leave the default) it fails with a PHP warning for Redis connect of no such file or directory in /var/www/nextcloud/lb/private/RedisFactory.php at line 84 and a “Malformed version”.
The main user access is not working (“Internal server error”), so my question is how best to recover the situation? All the data is on a USB drive, so hopefully should be safe (?). Should I just blow away the container/image, download a new one and create a new container, or is there a better way of restoring the current one?
