Hi
I have a question.
Why is there auto upload but does not support any obvious control over it. So it becam pretty much useless shit, because you need files on server but software does not want to upload. Manual start of that process is not possible. So you must go manualy upload sometimes lot and a lot of files. Why is then this auto upload when does not want to auto upload??
P.S. Thank you, that you gave option to preserve exif data on images upload. It was quite studip to automaticly erase / change files on upload. Automatics sometice sucks big time.
- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can.
replace me
replace me
replace me
replace me
- PHP version (e.g, 8.3):
replace me
replace me
replace me
replace me
replace me
Please provide the log entries from your Nextcloud log that are generated during the time of problem (via the Copy raw option from Administration settings->Logging screen or from your nextcloud.log
located in your data directory). Feel free to use a pastebin/gist service if necessary.
PASTE HERE
PASTE
PASTE HERE
The output of occ config:list system
or similar is best, but, if not possible, the contents of your config.php
file from /path/to/nextcloud
is fine (make sure to remove any identifiable information!):
PASTE HERE
The output of occ app:list
(if possible).
- Use the
preformatted text
formatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
