Nextcloud version (eg, 12.0.2): 18.0.0
Operating system and version (eg, Ubuntu 17.04): CentOS 7.6
Apache or nginx version (eg, Apache 2.4.25): nginx/1.16.1
PHP version (eg, 7.1): PHP 7.3.13
The issue you are facing: Converting an .odt document to PDF with the Automated PDF Conversion app using the Flows feature does not work.
- Install the Automated PDF Conversion app.
- Tag a document with “pdf”, such as the sample .odt file included with each NextCloud install.
- Create a Flow to automatically convert documents that have a tag added. Filter for the tag “pdf”.
- The document is not converted, and the error below appears in theNextCloud log.
OCA\DocumentServer\Document\DocumentConversionException: sh: ./x2t: Permission denied
/var/www/nextcloud/apps/documentserver_community/lib/Document/ConverterBinary.php - line 60:
OCA\DocumentServer\Document\ConverterBinary->run("")
/var/www/nextcloud/apps/documentserver_community/lib/Controller/StaticController.php - line 90:
OCA\DocumentServer\Document\ConverterBinary->test()
/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 170:
OCA\DocumentServer\Controller\StaticController->webApps("apps/api/documents/api.js")
/var/www/nextcloud/lib/private/AppFramework/Http/Dispatcher.php - line 99:
OC\AppFramework\Http\Dispatcher->executeController(OCA\Document ... {}, "webApps")
/var/www/nextcloud/lib/private/AppFramework/App.php - line 125:
OC\AppFramework\Http\Dispatcher->dispatch(OCA\Document ... {}, "webApps")
/var/www/nextcloud/lib/private/AppFramework/Routing/RouteActionHandler.php - line 47:
OC\AppFramework\App::main("OCA\\Docume ... r", "webApps", OC\AppFramew ... {}, { path: "app ... "})
<<closure>>
OC\AppFramework\Routing\RouteActionHandler->__invoke({ path: "app ... "})
/var/www/nextcloud/lib/private/Route/Router.php - line 299:
call_user_func(OC\AppFramew ... {}, { path: "app ... "})
/var/www/nextcloud/lib/base.php - line 1008:
OC\Route\Router->match("/apps/docum ... s")
/var/www/nextcloud/index.php - line 38:
OC::handleRequest()
'objectstore_multibucket' =>
'class' => 'OC\\Files\\ObjectStore\\S3',
'arguments' =>
'num_buckets' => 64,
'bucket' => 'REDACTED',
'autocreate' => true,
'key' => 'REDACTED',
'secret' => 'REDACTED',
'hostname' => 's3.example.com',
'port' => 443,
'use_ssl' => true,
'region' => 'REDACTED',
'use_path_style' => false,
'instanceid' => 'REDACTED',
'passwordsalt' => 'REDACTED',
0 => 'example.com',
'version' => '18.0.0.10',
'overwrite.cli.url' => 'https://example.com',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextcloud',
'dbpassword' => 'REDACTED',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'mail_smtpmode' => 'smtp',
'mail_smtpsecure' => 'tls',
'mail_smtpauth' => 1,
'mail_smtphost' => 'smtp.example.com',
'mail_smtpport' => '587',
'mail_from_address' => 'demo',
'mail_domain' => 'example.com',
'mail_smtpname' => 'apikey',
'mail_smtppassword' => 'REDACTED',
'loglevel' => 2,
'ldapIgnoreNamingRules' => false,
