Just installed the android app to backup my pics to the NC.
Took me a while to find out that the auto upload won’t work with already existing files.
After pushing a manual upload, I decided to go the “dirty” way and move around some subdirectories for the auto upload to trigger but it seems it will not kick in.
Instead, each subdir is recognized as an own folder available for sync.
Selecting a folder for manual upload is also not possible.
Is this really the way it should work?
Guys, is it really necessary to set up each subdir?
At this very moment, yes. This might change in the future in case someone finds the time to implement this
