Hey,
i setup my nextcloud last week and now I want to work with my calendar, in NC12 there is an app called calendar, that i want to use for me and my family. But when I want to enable it, there can an error message called “authentication required”. I used the same password as for the login and it failed now 15 times in different time areas.
[/details]
Please delete everything above when creating your topic and provide the following:
Nextcloud version (eg, 12.0.2): Nextcloud 12.0.5
Operating system and version (eg, Ubuntu 17.04): Debian 8 Jessie
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.10-10+deb8u11
PHP version (eg, 7.1): PHP5.6.30+dfsg-0+deb8u1
Thats the output of my psql.
List of databases
Name | Owner | Encoding | Collate | Ctype | Access privileges
nextcloud | postgres | UTF8 | en_US.UTF-8 | en_US.UTF-8 | =Tc/postgres +
| | | | | postgres=CTc/postgres+
| | | | | nextuser=CTc/postgres
|Warning|core|Login failed: 'muelleste' (Remote IP: '192.168.1.218')|2018-02-08T20:29:02+0000|
|Warning|core|Login failed: 'muelleste' (Remote IP: '192.168.1.218')|2018-02-08T20:28:58+0000|
datadirectory' => '/var/www/nextcloud/data',
'dbtype' => 'pgsql',
'version' => '12.0.5.3',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'nextuser',
'dbpass' ....
'updater.release.channel' => 'production',
[Thu Feb 08 21:15:47.440725 2018] [authz_core:error] [pid 27067] [client 192.168.1.218:45256] AH01630: client denied by server configuration: /var/www/nextcloud/data/.ocdata
[Thu Feb 08 21:15:54.207729 2018] [authz_core:error] [pid 28638] [client 192.168.1.218:45261] AH01630: client denied by server configuration: /var/www/nextcloud/data/.ocdata
What were going wrong, i can login to my site, but the authication to enable plugins failed ? But i am in the admin group.
