Hi all,
I upgraded my 9.0.53 installation to 10.0.0. Did this by running php occ upgrade as user www-data (I’m on Debian).
Since this upgrade, I don’t see any files or calendar entries. Web Interfaces says Problem loading page, reloading in 5 seconds.
Apache error log says:
[Wed Aug 31 19:01:47.479659 2016] [:error] [pid 4522] [client 2001:db8:1:1:ed64:4cb2:c227:b392:40452] PHP Fatal error: Uncaught exception 'Exception' with message 'Session has been closed - no further changes to the session are allowed' in /var/www/my-domain.de/cloud/lib/private/Session/Internal.php:154\nStack trace:\n#0 /var/www/my-domain.de/cloud/lib/private/Session/Internal.php(64): OC\Session\Internal->validateSession()\n#1 /var/www/my-domain.de/cloud/lib/private/Session/CryptoSessionData.php(164): OC\Session\Internal->set('encrypted_sessi...', 'e3b4eba3a833fa5...')\n#2 /var/www/my-domain.de/cloud/lib/private/Session/CryptoSessionData.php(67): OC\Session\CryptoSessionData->close()\n#3 [internal function]: OC\Session\CryptoSessionData->__destruct()\n#4 {main}\n thrown in /var/www/my-domain.de/cloud/lib/private/Session/Internal.php on line 154, referer: https://my-domain.de/cloud/
nextcloud.log says:
{"reqId":"O+0RJqz9QDOXkLpQrjyh","remoteAddr":"2001:db8:1:1:ed64:4cb2:c227:b392","app":"core","message":"Login failed: 'sven' (Remote IP: '2001:db8:1:1:ed64:4cb2:c227:b392')","level":2,"time":"2016-08-31T19:14:22+02:00","method":"GET","url":"\/cloud\/index.php\/apps\/files\/","user":"sven"}
here comes my config.php:
<?php $CONFIG = array ( 'instanceid' => 'oc4xxxxxxxxx', 'passwordsalt' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx', 'secret' => 'xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx', 'trusted_domains' => array ( 0 => 'my-domain.de', 1 => 'my-other-domain.de', ), 'datadirectory' => '/var/www/my-domain.de/cloud/data', 'overwrite.cli.url' => 'https://my-domain.de/cloud', 'dbtype' => 'mysql', 'version' => '9.1.0.16', 'dbname' => 'owncloud2', 'dbhost' => 'webserver', 'dbtableprefix' => 'oc_', 'dbuser' => 'owncloud', 'dbpassword' => 'xxxxxxxxxxxxxxxx', 'logtimezone' => 'Europe/Berlin', 'installed' => true, 'theme' => '', 'loglevel' => 2, 'maintenance' => false, 'user_backends' => array ( 0 => array ( 'class' => 'OC_User_IMAP', 'arguments' => array ( 0 => '{localhost:993/imap/ssl/novalidate-cert/notls/readonly}', ), ), ), 'htaccess.RewriteBase' => '/cloud', );
I changed nothing in config.php before/after the update. These settings worked fine with version 9.0.53.
As you can see, authentication is done against a local IMAP server. I suspect there might be a correlation.
Does anybody have an idea?
Thanks!
Sven
