Nextcloud version: 13.0.0
OS: Ubuntu 16.04.03 LTS
Apache 2.4.18
PHP 7.0.25
I need to be able to see what user viewed what files, preferably with the according time.
I have already read several posts about it, but none of the solutions seems to work for me.
The only thing that works so far is the User Usage Report, but that isn’t very specific. I have also loaded the Auditing / Logging app and even enabled the admin_audit, but I have no clue where I can check the logs that should be created, because I can’t find a single .log file that is affiliated with the nextcloud installation. Desperately looking for a solution.
