I have tried all what I found on net for this but still doesn’t work.
Scaning audio files stuck on random file.
I have installed php-smb and doesn’t help. I use nextcloud 14, latest version.
Is there any solution for this?
I have executed this sudo -u www-data php occ audioplayer:scan admin --debug
and that works withouth problems.
No update for this problem??? Any help?
as discussed on github, the next release should work better with the progress bar in the frontend. there seems to be some issue in your configuration because in general it seems to work.
the fix in the new version will take care of a know issue with the cache configuration
