Assistant is not working in Euro-Office in Docker Installation (Not AIO)
    • Docker Conainer inside Debian Trixie
    • Docker Containers. Not AIO
Assist not working in Euro-Office.
Additional Info:
Euro-office document server is installed in a seperate container.  And is updated regularly.
I'm running fully local installation. No certificate is used (plain http). Just for me and my family.
Assistant is working fine in the text editor, and also the chat is working fine (after fixing the delayed response problem picking the task).
  1. Click “Insert->Smart Picker” or pick the assistant Context menu or write “/ai” in the document
  2. Nothing happens
No messages are logged during the time of the problem
No messages appear in the web-developer console during the time of the problem
No messages appear in nginx logs during the time of the problem
        "force_ipv4": true,
        "log_type": "file",
        "loglevel": 0,
        "log_rotate_size": 10485760,
        "default_phone_region": "US",
        "maintenance_window_start": 2,
        "serverid": 1,
        "overwrite.cli.url": "http:\/\/***MY_LOCAL_URL***",
        "overwritehost": "***MY_LOCAL_URL***",
        "overwriteprotocol": "http",
            "***MY_LOCAL_IP***:***MY_PORT***",
        "redis": {
            "port": 6379,
        "htaccess.RewriteBase": "\/",
        "apps_paths": [
                "url": "\/apps",
                "writable": false
                "url": "\/custom_apps",
                "writable": true
        "upgrade.disable-web": true,
        "dbtype": "mysql",
        "version": "35.0.0.10",
        "mysql.utf8mb4": true,
        "defaultapp": "dashboard,files",
        "mail_smtpmode": "smtp",
        "mail_sendmailmode": "smtp",
        "mail_smtpstreamoptions": {
            "ssl": {
                "allow_self_signed": true,
                "verify_peer": false,
                "verify_peer_name": false
        "app.mail.verify-tls": false,
        "mail_verify_tls_peer": false,
        "app.mail.verify-tls-peer": false,
        "mail_smtpauth": true,
        "mail_smtpport": "587",
        "app_install_overwrite": []
  - activity: 8.0.0
  - appstore: 2.0.0-dev.0
  - assistant: 4.0.0
  - bruteforcesettings: 8.0.0
  - circles: 35.0.0
  - cloud_federation_api: 2.0.0-dev.0
  - comments: 2.0.0-dev.0
  - contacts: 8.9.0
  - contactsinteraction: 2.0.0-dev.0
  - dashboard: 8.0.0-dev.0
  - dav: 2.0.0-dev.1
  - deck: 1.19.0
  - eurooffice: 11.0.5
  - federatedfilesharing: 2.0.0-dev.1
  - federation: 2.0.0-dev.0
  - files: 3.0.0-dev.0
  - files_downloadlimit: 5.3.0
  - files_lock: 35.0.0
  - files_pdfviewer: 8.0.0
  - files_reminders: 2.0.0-dev.0
  - files_sharing: 2.0.0-dev.1
  - files_trashbin: 2.0.0-dev.0
  - files_versions: 2.0.0-dev.0
  - firstrunwizard: 8.0.0
  - integration_openai: 5.0.0
  - logreader: 8.0.0
  - lookup_server_connector: 2.0.0-dev.0
  - mail: 5.12.0
  - nextcloud_announcements: 7.0.0
  - notifications: 8.0.0
  - oauth2: 2.0.0-dev.0
  - office: 1.1.0
  - password_policy: 7.0.0
  - privacy: 7.0.0
  - profile: 2.0.0-dev.0
  - provisioning_api: 2.0.0-dev.0
  - related_resources: 6.0.0
  - serverinfo: 7.0.0
  - settings: 2.0.0-dev.0
  - sharebymail: 2.0.0-dev.0
  - sharing: 1.0.4
  - spreed: 25.0.0
  - support: 7.0.0
  - survey_client: 7.0.0
  - systemtags: 2.0.0-dev.0
  - text: 9.0.0
  - theming: 3.0.0-dev.0
  - twofactor_backupcodes: 2.0.0-dev.0
  - twofactor_totp: 17.1.0
  - updatenotification: 2.0.0-dev.0
  - user_status: 2.0.0-dev.0
  - viewer: 8.0.0
  - webhook_listeners: 2.0.0-dev.0
  - workflowengine: 3.0.0-dev.0
  - admin_audit: 2.0.0-dev.0
  - app_api: 35.0.0 (installed 33.0.0)
  - drawio: 4.3.8 (installed 4.3.8)
  - encryption: 3.0.0-dev.0
  - files_external: 2.0.0-dev.0 (installed 1.25.1)
  - photos: 8.0.0 (installed 6.0.0-dev.0)
  - recommendations: 8.0.0 (installed 6.0.0-dev.0)
  - suspicious_login: 13.0.0
  - twofactor_nextcloud_notification: 9.0.0
  - user_ldap: 2.0.0-dev.0
  - weather_status: 2.0.0-dev.0 (installed 1.13.0)
