- Official documentation (searchable and regularly updated)
- How to topics and FAQs
- Forum search
Some or all of the below information will be requested if it isn’t supplied; for fastest response please provide as much as you can.
30.04
Ubuntu 24.04.1
Apache 2.4.58
replace me
- PHP version (e.g, 8.3):
8.3
yes
first install
Archive
No
I need to add LDAP users automatically to a specific group in nextcloud. I created a group (ex. ldap_user) in “Accounts” page, but synced LDAP users can’t be assigned to this group automatically, I have to do it manually for each user
- in Accounts page create a new group (ex… ldap_import)
- configure LDAP and import users
- imported users from LDAP not assigned to this group (ldap_import)
Please provide the log entries from your Nextcloud log that are generated during the time of problem (via the Copy raw option from Administration settings->Logging screen or from your nextcloud.log
located in your data directory). Feel free to use a pastebin/gist service if necessary.
PASTE HERE
PASTE
PASTE HERE
The output of occ config:list system
or similar is best, but, if not possible, the contents of your config.php
file from /path/to/nextcloud
is fine (make sure to remove any identifiable information!):
PASTE HERE
The output of occ app:list
(if possible).
- Use the
preformatted text
formatting option in the editor for all log entries and configuration output. - If screenshots are useful, feel free to include them.
- If possible, also include key error output in text form so it can be searched for.
- Try to edit log output only minimally (if at all) so that it can be ran through analyzers / formatters by those trying to help you.
