Appointments view too wide and does not condense to viewable area
After updating to 30.6 it looks like there was a change to how the appointments view looks as it is not displaying the available slots below the date picker. Previously the slots were below the date selection, now when I’m viewing the public shared view for the appointments the slots are off to the right and do not collapse below the date picker. is this intended or a bug? if this is intended it complicates things by not allowing the view to be dynamic and collapse to a smaller view for example when the view is embedded in an iframe, it also has a lot of wasted space below the date picker now. it would be preferable to have the view collapse below and be flexible enough to show the appointments on a smaller view for mobile display. this is especially problematic when i switch to mobile view in dev tools which makes the available slots not even visible and the view of appointments not usable.
updated to 30.7 and still seeing the same thing in the embedded appointment view.
Updated to 31.02 and still seeing the same issue
this is the github issue tracker i opened.
this is easily reproduced by opening dev tools and set view to mobile.
