AppImage 3.16.0-x86_64 does not run
    • 30.0.6
    • Ubuntu 24.10
    • replace me
    • replace me
    • replace me
    • Yes
    • After upgrading from previous version`
    • replace me
  • Cannot launch AppImage client on Ubuntu desktop
  1. Ensure Executable as Program Permissions is ON
  2. Run Nextcloud-3.16.0-x86_64.AppImage
  3. Nothing happens
PASTE HERE
PASTE
PASTE HERE
PASTE HERE
It looks like the issue is related to version 3.16.0 AppImage. Try updating to the latest 3.16.1, which is now available:
Nextcloud 3.16.1 AppImage
If the issue persists, try running it in a terminal to check for error messages:
./Nextcloud-3.16.1-x86_64.AppImage
If you see errors related to sandboxing, you can try launching it with:
./Nextcloud-3.16.1-x86_64.AppImage --no-sandbox
Let us know if the new version resolves the issue.
Thanks for the quick reply! That is a BIG help for me. I should’ve checked for upgrade(s) even though my client has the functionality enabled.
Regards.
P.S.
3.16.1 launches but need to perform my due diligence, of course!
