example
longer
example
here
Nextcloud version (eg, 20.0.5): 23.0.2
Operating system and version (eg, Ubuntu 20.04): Debian Bullseye
Apache or nginx version (eg, Apache 2.4.25): dont know
PHP version (eg, 7.4): 7.4
[index] Fehler: Argument 1 passed to OCA\Cookbook\Helper\UserConfigHelper::__construct() must be of the type string, null given
GET /index.php/apps/cookbook/categories
from 192.168.2.188 at 2022-04-13T06:39:55+00:00
'passwordsalt' => 'removed',
'secret' => 'removed',
0 => 'localhost',
7 => 'here was the local dns address',
5 => 'nextcloudpi.local',
8 => 'nextcloudpi.lan',
3 => 'here was the local dns address',
11 => 'removed',
1 => 'here was the local ip address',
14 => 'here was the local dns address',
20 => 'here was the web domain name',
'datadirectory' => '/srv/nextcloud/ncdata/data',
'version' => '23.0.2.1',
'overwrite.cli.url' => 'https://removed/',
'dbname' => 'nextcloud',
'dbhost' => 'localhost',
'dbuser' => 'ncadmin',
'dbpassword' => 'removed',
'instanceid' => 'removed',
'redis' =>
'host' => '/var/run/redis/redis.sock',
'port' => 0,
'timeout' => 0.0,
'password' => 'removed',
'tempdirectory' => '/srv/nextcloud/ncdata/data/tmp',
'mail_smtpmode' => 'sendmail',
'mail_from_address' => 'admin',
'mail_domain' => 'ownyourbits.com',
'preview_max_x' => '2048',
'preview_max_y' => '2048',
'jpeg_quality' => '60',
'trusted_proxies' =>
11 => '127.0.0.1',
12 => '::1',
13 => 'here was the local dns name,
14 => '',
'loglevel' => '2',
'log_type' => 'file',
'twofactor_enforced' => 'true',
0 => 'user',
1 => 'admin',
'has_rebuilt_cache' => true,
'logfile' => '/srv/nextcloud/ncdata/data/nextcloud.log',
nc-access.log:
93.210.201.98 - - [13/Apr/2022:08:41:17 +0200] "GET /ocs/v2.php/core/getapppassword HTTP/1.1" 403 6766 "-" "Cookbook App"
93.210.201.98 - - [13/Apr/2022:08:41:29 +0200] "GET /ocs/v2.php/core/getapppassword HTTP/1.1" 403 6770 "-" "Cookbook App"
93.210.201.98 - - [13/Apr/2022:08:42:20 +0200] "GET /index.php/apps/theming/icon?v=27 HTTP/2.0" 200 87403 "-" "Mozilla/5.0 (Android 11; Mobile; rv:99.0) Gecko/99.0 Firefox/99.0"
93.210.201.98 - - [13/Apr/2022:08:44:51 +0200] "GET /ocs/v2.php/core/getapppassword HTTP/1.1" 403 6774 "-" "Cookbook App"
93.210.201.98 - - [13/Apr/2022:08:44:58 +0200] "GET /ocs/v2.php/core/getapppassword HTTP/1.1" 403 6768 "-" "Cookbook App"
93.210.201.98 - - [13/Apr/2022:11:26:59 +0200] "GET /ocs/v2.php/core/getapppassword HTTP/1.1" 403 6768 "-" "Cookbook App"
93.210.201.98 - - [13/Apr/2022:11:27:54 +0200] "GET /ocs/v2.php/core/getapppassword HTTP/1.1" 403 6782 "-" "Cookbook App"
93.210.201.98 - - [13/Apr/2022:11:53:33 +0200] "GET /ocs/v2.php/apps/spreed/api/v4/room HTTP/2.0" 403 769 "-" "Mozilla/5.0 (X11; Linux x86_64; rv:99.0) Gecko/20100101 Firefox/99.0"
PASTE HERE
{"reqId":"REMOVED","level":3,"time":"2022-04-13T06:39:55+00:00","remoteAddr":"192.168.2.188","user":"--","app":"index","method":"GET","url":"/index.php/apps/cookbook/categories","message":"Argument 1 passed to OCA\\Cookbook\\Helper\\UserConfigHelper::__construct() must be of the type string, null given","userAgent":"Dart/2.14 (dart:io)","version":"23.0.2.1","exception":{"Exception":"TypeError","Message":"Argument 1 passed to OCA\\Cookbook\\Helper\\UserConfigHelper::__construct() must be of the type string, null given","Code":0,"Trace":[{"function":"__construct","class":"OCA\\Cookbook\\Helper\\UserConfigHelper","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":106,"function":"newInstanceArgs","class":"ReflectionClass","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":114,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":131,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":463,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":435,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":87,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":106,"function":"array_map"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":114,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":131,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":463,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":435,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":87,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":106,"function":"array_map"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":114,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/Utility/SimpleContainer.php","line":131,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":463,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/DependencyInjection/DIContainer.php","line":435,"function":"queryNoFallback","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/AppFramework/App.php","line":144,"function":"query","class":"OC\\AppFramework\\DependencyInjection\\DIContainer","type":"->"},{"file":"/var/www/nextcloud/lib/private/Route/Router.php","line":302,"function":"main","class":"OC\\AppFramework\\App","type":"::"},{"file":"/var/www/nextcloud/lib/base.php","line":1006,"function":"match","class":"OC\\Route\\Router","type":"->"},{"file":"/var/www/nextcloud/index.php","line":36,"function":"handleRequest","class":"OC","type":"::"}],"File":"/var/www/nextcloud/apps/cookbook/lib/Helper/UserConfigHelper.php","Line":28,"CustomMessage":"--"}}
Hi folks,
I setup an Nextcloudpi instance to my Raspberry Pi. Everythink works good.
I use TOTP auth for better security and assigned some app token’s for my mobile.
Now I saw, non of them works. I get an error “403 Forbidden”, when I try to use a token.
The log’s above are for the Cookbook app.
Did I configure anything wrong, or what cloud be the problem?
Sorry, I’m not a webserver specialist, so don´t be so hard with missconfigurations!
Many thanks
Cheers
Buzzzz
