Nextcloud version (eg, 20.0.5): 22
Operating system and version (eg, Ubuntu 20.04): Debian 11
Apache or nginx version (eg, Apache 2.4.25): Apache 2.4.52
PHP version (eg, 7.4): 8.1
Hello everyone,
I’m trying to set up the mpm_itk module for my nextcloud instance but it’s not working.
I’ve created a nextcloud user on my debian server and i want apache to use this specific user for my NC instance.
When i enable mpm_itk in my nextcloud.conf then i can’t access it the gui and i got this error
[Thu Mar 10 12:08:49.398192 2022] [mpm_itk:warn] [pid 471354] (itkmpm: pid=471354 uid=1001, gid=1001) itk_post_perdir_config(): setgid(33): Operation not permitted
[Thu Mar 10 12:08:49.398221 2022] [mpm_itk:warn] [pid 471354] Couldn't set uid/gid/priority, closing connection.
i’ve got other website that works well with apache and mpm_itk so i guess the problem is not coming from the module itself but more from nextcloud and the permission of the nextcloud folder in var/www
the module is called that way in my nextcloud.conf
<IfModule mpm_itk_module>
AssignUserId nextcloud nextcloud
</IfModule>
and i’ve set ownership of the nextcloud folder to user nextcloud and group nextcloud.
in case i’ve had the user www-data in the nextcloud group but still not working.
the nextcloud folder (located in var/www) and its entire content is set to 750 regarding permissions.
for now i went back to www-data ownership and disabled the module in the nextcloud.conf
thanks a lot for your help.
