Iāll try that. Have you tried downgrading to 3.7.2 to see if it works for you?
Iāll try that, im currently at android 3.8.0 app and the dev version, thanks
Are you behind cloudflare by any chance?
I am, yes.
So I think I got it working by disabling cloudflare proxy on the domainā¦ It only worked for a few minutes so far, I will need to check later.
Problem could be dns towards the webpage, or something like that, since phone network provider use a different dns server than I do with my ISP / router.
I will try to add the following ips to the trusted proxy ones in my config and see if it works any better wirh cloudflare enabledā¦ https://www.cloudflare.com/ips/
Disabling cloudflare proxy to my domain where my nextcloud reside, seems to solve the issue.
@bozrdang please try that you as well!
I temporarily disabled Cloudflare and indeed wifi uploads work now. I havenāt changed my configuration in over a year now so I wonder why it just recently stopped working.
So to add the IPs to the trusted proxy list using a wildcard, is it simply 173.245.48.x?
Weeelll I think you need to use /xx to define ranges. I guess nc documentation tells more. Iām a bit busy this weekend so Iāll look more into it tomorrow evening. Might be some header rewrites too, but not sure.
Well searching shows the * is the wildcard. I tried adding the IPs with and without the / bits and nothing seems to work with Cloudflare enabled but I am probably doing something wrong. You obviously know a lot more about this than I know as I don;t know anything about headers. Please let me know if you find something that works.
identical issue here, I also use cloudflare.
solution:
cloudflare->firewall->settings->disable āBrowser Integrity Checkā
works great!
Indeed it does. Thanks!
That was it! Thank you so much!
Just wanted to add that upload worked fine with my IOS clients and āBrowser Integrety Checkā enabled. I assume itās an error in the Android client only.
Regards
