just tried looking at your logfile… but it’s cut off at the end.
though 1 question: u sure youre running nextcloud client? i read something like owncloudclient
plus:
most prolly it’s a huwei-OS-based problem… have sou investigated that, already?
awww. wait there was some information about those apps from F-Droid… like they don’t have the same functionality as their google-playstore-version due to some google processes. maybe that would apply in some way to your problem as well?! - dunno. but a starting point for further investigation
so you say the message comes up but doesnt mean anything?
ref: releasing in appgallery… f-droid isn’t the problem, itself. the problem is some connection (i forgot which one exactly) between some google-processes…
