[/details]
Nextcloud version (eg, 20.0.5): 24.0.7
Operating system and version (eg, Ubuntu 20.04): centos 7
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): 7.4
Android App 3.22.3
MobilePhone: Samsung Xcover 5 Android 12
Usually my AutoUpload Folders are all set up with:
Use Only WLAN without Fees
Upload only while Charging Battery
If now there is a file to be uploaded via the AutoUpload mechanism and there is no powercable connected, the battery usage of Nextcloud rises to more than 2% in about 30 min.
Well, yeah the Xcover has only a small battery…
Battery usage increase stops after the files have finally been uploaded by attaching a power cable
If the AutoUpload Folder had the “only while charging” removed and a new file is crated in there
the whole process of uploading consumes almost no additional power.
Thus instead of saving battery the “only while charging” wastes battery power.
- set up AutoUpload folder like mentioned above
- remove charging cable
- create file in monitored folder
- wait half an hour or an hour depending on battery capacity
- see the battery usage for nextcloud rise
