example
longer
example
here
Nextcloud version (eg, 20.0.5): 24.0.1
Operating system and version (eg, Ubuntu 20.04): Hosted in Cpanel
Apache or nginx version (eg, Apache 2.4.25): replace me
PHP version (eg, 7.4): 7.4.33
Update to 24.0.1
Doctrine\DBAL\Exception\DriverException: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 2013 Lost connection to MySQL server during query
Repair error: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 2013 Lost connection to MySQL server during query
Is this the first time you’ve seen this error? (Y/N):N
- Run the update. Fails every time. I can restore the server back to before I try and get it back online but then if I try to update again it fails again.
Update to 24.0.1
Detailed logs
Preparing update
Set log level to debug
Turned on maintenance mode
Repair step: Repair MySQL collation
Repair info: Change row format for oc_accounts ...
Repair info: Change collation for oc_accounts ...
Repair info: Change row format for oc_accounts_data ...
Repair info: Change collation for oc_accounts_data ...
Repair info: Change row format for oc_activity ...
Repair info: Change collation for oc_activity ...
Repair info: Change row format for oc_activity_mq ...
Repair info: Change collation for oc_activity_mq ...
Repair info: Change row format for oc_addressbookchanges ...
Repair info: Change collation for oc_addressbookchanges ...
Repair info: Change row format for oc_addressbooks ...
Repair info: Change collation for oc_addressbooks ...
Repair info: Change row format for oc_appconfig ...
Repair info: Change collation for oc_appconfig ...
Repair info: Change row format for oc_audioplayer_albums ...
Repair info: Change collation for oc_audioplayer_albums ...
Repair info: Change row format for oc_audioplayer_artists ...
Repair info: Change collation for oc_audioplayer_artists ...
Repair info: Change row format for oc_audioplayer_genre ...
Repair info: Change collation for oc_audioplayer_genre ...
Repair info: Change row format for oc_audioplayer_playlists ...
Repair info: Change collation for oc_audioplayer_playlists ...
Repair info: Change row format for oc_audioplayer_stats ...
Repair info: Change collation for oc_audioplayer_stats ...
Repair info: Change row format for oc_audioplayer_streams ...
Repair info: Change collation for oc_audioplayer_streams ...
Repair info: Change row format for oc_audioplayer_tracks ...
Repair info: Change collation for oc_audioplayer_tracks ...
Repair info: Change row format for oc_audioplayer_whats_new ...
Repair info: Change collation for oc_audioplayer_whats_new ...
Repair info: Change row format for oc_authorized_groups ...
Repair info: Change collation for oc_authorized_groups ...
Repair info: Change row format for oc_authtoken ...
Repair info: Change collation for oc_authtoken ...
Repair info: Change row format for oc_bookmarks ...
Repair info: Change collation for oc_bookmarks ...
Repair info: Change row format for oc_bookmarks_folders ...
Repair info: Change collation for oc_bookmarks_folders ...
Repair info: Change row format for oc_bookmarks_folders_public ...
Repair info: Change collation for oc_bookmarks_folders_public ...
Repair info: Change row format for oc_bookmarks_root_folders ...
Repair info: Change collation for oc_bookmarks_root_folders ...
Repair info: Change row format for oc_bookmarks_shared_folders ...
Repair info: Change collation for oc_bookmarks_shared_folders ...
Repair info: Change row format for oc_bookmarks_shares ...
Repair info: Change collation for oc_bookmarks_shares ...
Repair info: Change row format for oc_bookmarks_tags ...
Repair info: Change collation for oc_bookmarks_tags ...
Repair info: Change row format for oc_bookmarks_tree ...
Repair info: Change collation for oc_bookmarks_tree ...
Repair info: Change row format for oc_bruteforce_attempts ...
Repair info: Change collation for oc_bruteforce_attempts ...
Repair info: Change row format for oc_calendar_appt_bookings ...
Repair info: Change collation for oc_calendar_appt_bookings ...
Repair info: Change row format for oc_calendar_appt_configs ...
Repair info: Change collation for oc_calendar_appt_configs ...
Repair info: Change row format for oc_calendar_invitations ...
Repair info: Change collation for oc_calendar_invitations ...
Repair info: Change row format for oc_calendar_reminders ...
Repair info: Change collation for oc_calendar_reminders ...
Repair info: Change row format for oc_calendar_resources ...
Repair info: Change collation for oc_calendar_resources ...
Repair info: Change row format for oc_calendar_resources_md ...
Repair info: Change collation for oc_calendar_resources_md ...
Repair info: Change row format for oc_calendar_rooms ...
Repair info: Change collation for oc_calendar_rooms ...
Repair info: Change row format for oc_calendar_rooms_md ...
Repair info: Change collation for oc_calendar_rooms_md ...
Repair info: Change row format for oc_calendarchanges ...
Repair info: Change collation for oc_calendarchanges ...
Repair info: Change row format for oc_calendarobjects ...
Repair info: Change collation for oc_calendarobjects ...
Repair info: Change row format for oc_calendarobjects_props ...
Repair info: Change collation for oc_calendarobjects_props ...
Repair info: Change row format for oc_calendars ...
Repair info: Change collation for oc_calendars ...
Repair info: Change row format for oc_calendarsubscriptions ...
Repair info: Change collation for oc_calendarsubscriptions ...
Repair info: Change row format for oc_cards ...
Repair info: Change collation for oc_cards ...
Repair info: Change row format for oc_cards_properties ...
Repair info: Change collation for oc_cards_properties ...
Repair info: Change row format for oc_circles_circle ...
Repair info: Change collation for oc_circles_circle ...
Repair info: Change row format for oc_circles_event ...
Repair info: Change collation for oc_circles_event ...
Repair info: Change row format for oc_circles_member ...
Repair info: Change collation for oc_circles_member ...
Repair info: Change row format for oc_circles_membership ...
Repair info: Change collation for oc_circles_membership ...
Repair info: Change row format for oc_circles_mount ...
Repair info: Change collation for oc_circles_mount ...
Repair info: Change row format for oc_circles_mountpoint ...
Repair info: Change collation for oc_circles_mountpoint ...
Repair info: Change row format for oc_circles_remote ...
Repair info: Change collation for oc_circles_remote ...
Repair info: Change row format for oc_circles_share_lock ...
Repair info: Change collation for oc_circles_share_lock ...
Repair info: Change row format for oc_circles_token ...
Repair info: Change collation for oc_circles_token ...
Repair info: Change row format for oc_collres_accesscache ...
Repair info: Change collation for oc_collres_accesscache ...
Repair info: Change row format for oc_collres_collections ...
Repair info: Change collation for oc_collres_collections ...
Repair info: Change row format for oc_collres_resources ...
Repair info: Change collation for oc_collres_resources ...
Repair info: Change row format for oc_comments ...
Repair info: Change collation for oc_comments ...
Repair info: Change row format for oc_comments_read_markers ...
Repair info: Change collation for oc_comments_read_markers ...
Repair info: Change row format for oc_cospend_bills ...
Repair info: Change collation for oc_cospend_bills ...
Repair info: Change row format for oc_cospend_categories ...
Repair info: Change collation for oc_cospend_categories ...
Repair info: Change row format for oc_cospend_currencies ...
Repair info: Change collation for oc_cospend_currencies ...
Repair info: Change row format for oc_cospend_members ...
Repair info: Change collation for oc_cospend_members ...
Repair info: Change row format for oc_cospend_paymentmodes ...
Repair info: Change collation for oc_cospend_paymentmodes ...
Repair info: Change row format for oc_cospend_projects ...
Repair info: Change collation for oc_cospend_projects ...
Repair info: Change row format for oc_cospend_shares ...
Repair info: Change collation for oc_cospend_shares ...
Repair info: Change row format for oc_dav_cal_proxy ...
Repair info: Change collation for oc_dav_cal_proxy ...
Repair info: Change row format for oc_dav_shares ...
Repair info: Change collation for oc_dav_shares ...
Repair info: Change row format for oc_deck_assigned_users ...
Repair info: Change collation for oc_deck_assigned_users ...
Repair info: Change row format for oc_deck_attachment ...
Repair info: Change collation for oc_deck_attachment ...
Repair info: Change row format for oc_deck_board_acl ...
Repair info: Change collation for oc_deck_board_acl ...
Repair info: Change row format for oc_deck_boards ...
Repair info: Change collation for oc_deck_boards ...
Repair info: Change row format for oc_deck_cards ...
Repair info: Change collation for oc_deck_cards ...
Repair info: Change row format for oc_deck_labels ...
Repair info: Change collation for oc_deck_labels ...
Repair info: Change row format for oc_deck_stacks ...
Repair info: Change collation for oc_deck_stacks ...
Repair info: Change row format for oc_direct_edit ...
Repair info: Change collation for oc_direct_edit ...
Repair info: Change row format for oc_directlink ...
Repair info: Change collation for oc_directlink ...
Repair info: Change row format for oc_federated_reshares ...
Repair info: Change collation for oc_federated_reshares ...
Repair info: Change row format for oc_file_locks ...
Repair info: Change collation for oc_file_locks ...
Repair info: Change row format for oc_file_metadata ...
Repair info: Change collation for oc_file_metadata ...
Repair info: Change row format for oc_filecache ...
Repair info: Change collation for oc_filecache ...
Repair info: Change row format for oc_filecache_extended ...
Repair info: Change collation for oc_filecache_extended ...
Repair info: Change row format for oc_files_trash ...
Repair info: Change collation for oc_files_trash ...
Repair info: Change row format for oc_flow_checks ...
Repair info: Change collation for oc_flow_checks ...
Repair info: Change row format for oc_flow_operations ...
Repair info: Change collation for oc_flow_operations ...
Repair info: Change row format for oc_flow_operations_scope ...
Repair info: Change collation for oc_flow_operations_scope ...
Repair info: Change row format for oc_forms_v2_answers ...
Repair info: Change collation for oc_forms_v2_answers ...
Repair info: Change row format for oc_forms_v2_forms ...
Repair info: Change collation for oc_forms_v2_forms ...
Repair info: Change row format for oc_forms_v2_options ...
Repair info: Change collation for oc_forms_v2_options ...
Repair info: Change row format for oc_forms_v2_questions ...
Repair info: Change collation for oc_forms_v2_questions ...
Repair info: Change row format for oc_forms_v2_submissions ...
Repair info: Change collation for oc_forms_v2_submissions ...
Repair info: Change row format for oc_geoblocker_ls_rir ...
Repair info: Change collation for oc_geoblocker_ls_rir ...
Repair info: Change row format for oc_group_admin ...
Repair info: Change collation for oc_group_admin ...
Repair info: Change row format for oc_group_folders ...
Repair info: Change collation for oc_group_folders ...
Repair info: Change row format for oc_group_folders_acl ...
Repair info: Change collation for oc_group_folders_acl ...
Repair info: Change row format for oc_group_folders_groups ...
Repair info: Change collation for oc_group_folders_groups ...
Repair info: Change row format for oc_group_folders_manage ...
Repair info: Change collation for oc_group_folders_manage ...
Repair info: Change row format for oc_group_folders_trash ...
Repair info: Change collation for oc_group_folders_trash ...
Repair info: Change row format for oc_group_user ...
Repair info: Change collation for oc_group_user ...
Repair info: Change row format for oc_groups ...
Repair info: Change collation for oc_groups ...
Repair info: Change row format for oc_jobs ...
Repair info: Change collation for oc_jobs ...
Repair info: Change row format for oc_known_users ...
Repair info: Change collation for oc_known_users ...
Repair info: Change row format for oc_login_flow_v2 ...
Repair info: Change collation for oc_login_flow_v2 ...
Repair info: Change row format for oc_mail_accounts ...
Repair info: Change collation for oc_mail_accounts ...
Repair info: Change row format for oc_mail_aliases ...
Repair info: Change collation for oc_mail_aliases ...
Repair info: Change row format for oc_mail_attachments ...
Repair info: Change collation for oc_mail_attachments ...
Repair info: Change row format for oc_mail_classifiers ...
Repair info: Change collation for oc_mail_classifiers ...
Repair info: Change row format for oc_mail_coll_addresses ...
Repair info: Change collation for oc_mail_coll_addresses ...
Repair info: Change row format for oc_mail_local_messages ...
Repair info: Change collation for oc_mail_local_messages ...
Repair info: Change row format for oc_mail_mailboxes ...
Repair info: Change collation for oc_mail_mailboxes ...
Repair info: Change row format for oc_mail_message_tags ...
Repair info: Change collation for oc_mail_message_tags ...
Repair info: Change row format for oc_mail_messages ...
Repair info: Change collation for oc_mail_messages ...
Repair info: Change row format for oc_mail_provisionings ...
Repair info: Change collation for oc_mail_provisionings ...
Repair info: Change row format for oc_mail_recipients ...
Repair info: Change collation for oc_mail_recipients ...
Repair info: Change row format for oc_mail_tags ...
Repair info: Change collation for oc_mail_tags ...
Repair info: Change row format for oc_mail_trusted_senders ...
Repair info: Change collation for oc_mail_trusted_senders ...
Repair info: Change row format for oc_maps_address_geo ...
Repair info: Change collation for oc_maps_address_geo ...
Repair info: Change row format for oc_maps_apikeys ...
Repair info: Change collation for oc_maps_apikeys ...
Repair info: Change row format for oc_maps_devices ...
Repair info: Change collation for oc_maps_devices ...
Repair info: Change row format for oc_maps_favorite_shares ...
Repair info: Change collation for oc_maps_favorite_shares ...
Repair info: Change row format for oc_maps_favorites ...
Repair info: Change collation for oc_maps_favorites ...
Repair info: Change row format for oc_maps_photos ...
Repair info: Change collation for oc_maps_photos ...
Repair info: Change row format for oc_maps_tracks ...
Repair info: Change collation for oc_maps_tracks ...
Repair info: Change row format for oc_migrations ...
Repair info: Change collation for oc_migrations ...
Repair info: Change row format for oc_mimetypes ...
Repair info: Change collation for oc_mimetypes ...
Repair info: Change row format for oc_mounts ...
Repair info: Change collation for oc_mounts ...
Repair info: Change row format for oc_music_albums ...
Repair info: Change collation for oc_music_albums ...
Repair info: Change row format for oc_music_ampache_sessions ...
Repair info: Change collation for oc_music_ampache_sessions ...
Repair info: Change row format for oc_music_ampache_users ...
Repair info: Change collation for oc_music_ampache_users ...
Repair info: Change row format for oc_music_artists ...
Repair info: Change collation for oc_music_artists ...
Repair info: Change row format for oc_music_bookmarks ...
Repair info: Change collation for oc_music_bookmarks ...
Repair info: Change row format for oc_music_cache ...
Repair info: Change collation for oc_music_cache ...
Repair info: Change row format for oc_music_genres ...
Repair info: Change collation for oc_music_genres ...
Repair info: Change row format for oc_music_playlists ...
Repair info: Change collation for oc_music_playlists ...
Repair info: Change row format for oc_music_podcast_channels ...
Repair info: Change collation for oc_music_podcast_channels ...
Repair info: Change row format for oc_music_podcast_episodes ...
Repair info: Change collation for oc_music_podcast_episodes ...
Repair info: Change row format for oc_music_radio_stations ...
Repair info: Change collation for oc_music_radio_stations ...
Repair info: Change row format for oc_music_tracks ...
Repair info: Change collation for oc_music_tracks ...
Repair info: Change row format for oc_news_feeds ...
Repair info: Change collation for oc_news_feeds ...
Repair info: Change row format for oc_news_folders ...
Repair info: Change collation for oc_news_folders ...
Repair info: Change row format for oc_news_items ...
Repair info: Change collation for oc_news_items ...
Repair info: Change row format for oc_notes_meta ...
Repair info: Change collation for oc_notes_meta ...
Repair info: Change row format for oc_notifications ...
Repair info: Change collation for oc_notifications ...
Repair info: Change row format for oc_notifications_pushhash ...
Repair info: Change collation for oc_notifications_pushhash ...
Repair info: Change row format for oc_notifications_settings ...
Repair info: Change collation for oc_notifications_settings ...
Repair info: Change row format for oc_oauth2_access_tokens ...
Repair info: Change collation for oc_oauth2_access_tokens ...
Repair info: Change row format for oc_oauth2_clients ...
Repair info: Change collation for oc_oauth2_clients ...
Repair info: Change row format for oc_passwords_challenge ...
Repair info: Change collation for oc_passwords_challenge ...
Repair info: Change row format for oc_passwords_folder ...
Repair info: Change collation for oc_passwords_folder ...
Repair info: Change row format for oc_passwords_folder_rv ...
Repair info: Change collation for oc_passwords_folder_rv ...
Repair info: Change row format for oc_passwords_keychain ...
Repair info: Change collation for oc_passwords_keychain ...
Repair info: Change row format for oc_passwords_password ...
Repair info: Change collation for oc_passwords_password ...
Repair info: Change row format for oc_passwords_password_rv ...
Repair info: Change collation for oc_passwords_password_rv ...
Repair info: Change row format for oc_passwords_pw_tag_rel ...
Repair info: Change collation for oc_passwords_pw_tag_rel ...
Repair info: Change row format for oc_passwords_registration ...
Repair info: Change collation for oc_passwords_registration ...
Repair info: Change row format for oc_passwords_session ...
Repair info: Change collation for oc_passwords_session ...
Repair info: Change row format for oc_passwords_share ...
Repair info: Change collation for oc_passwords_share ...
Repair info: Change row format for oc_passwords_tag ...
Repair info: Change collation for oc_passwords_tag ...
Repair info: Change row format for oc_passwords_tag_rv ...
Repair info: Change collation for oc_passwords_tag_rv ...
Repair info: Change row format for oc_preferences ...
Repair info: Change collation for oc_preferences ...
Repair info: Change row format for oc_privacy_admins ...
Repair info: Change collation for oc_privacy_admins ...
Repair info: Change row format for oc_profile_config ...
Repair info: Change collation for oc_profile_config ...
Repair info: Change row format for oc_properties ...
Repair info: Change collation for oc_properties ...
Repair info: Change row format for oc_ratelimit_entries ...
Repair info: Change collation for oc_ratelimit_entries ...
Repair info: Change row format for oc_reactions ...
Repair info: Change collation for oc_reactions ...
Repair info: Change row format for oc_recent_contact ...
Repair info: Change collation for oc_recent_contact ...
Repair info: Change row format for oc_richdocuments_assets ...
Repair info: Change collation for oc_richdocuments_assets ...
Repair info: Change row format for oc_richdocuments_direct ...
Repair info: Change collation for oc_richdocuments_direct ...
Repair info: Change row format for oc_richdocuments_template ...
Repair info: Change collation for oc_richdocuments_template ...
Repair info: Change row format for oc_richdocuments_wopi ...
Repair info: Change collation for oc_richdocuments_wopi ...
Repair info: Change row format for oc_schedulingobjects ...
Repair info: Change collation for oc_schedulingobjects ...
Repair info: Change row format for oc_share ...
Repair info: Change collation for oc_share ...
Repair info: Change row format for oc_share_external ...
Repair info: Change collation for oc_share_external ...
Repair info: Change row format for oc_sip_trip_phone ...
Repair info: Change collation for oc_sip_trip_phone ...
Repair info: Change row format for oc_storages ...
Repair info: Change collation for oc_storages ...
Repair info: Change row format for oc_storages_credentials ...
Repair info: Change collation for oc_storages_credentials ...
Repair info: Change row format for oc_systemtag ...
Repair info: Change collation for oc_systemtag ...
Repair info: Change row format for oc_systemtag_group ...
Repair info: Change collation for oc_systemtag_group ...
Repair info: Change row format for oc_systemtag_object_mapping ...
Repair info: Change collation for oc_systemtag_object_mapping ...
Repair info: Change row format for oc_talk_attachments ...
Repair info: Change collation for oc_talk_attachments ...
Repair info: Change row format for oc_talk_attendees ...
Repair info: Change collation for oc_talk_attendees ...
Repair info: Change row format for oc_talk_bridges ...
Repair info: Change collation for oc_talk_bridges ...
Repair info: Change row format for oc_talk_commands ...
Repair info: Change collation for oc_talk_commands ...
Repair info: Change row format for oc_talk_internalsignaling ...
Repair info: Change collation for oc_talk_internalsignaling ...
Repair info: Change row format for oc_talk_invitations ...
Repair info: Change collation for oc_talk_invitations ...
Repair info: Change row format for oc_talk_rooms ...
Repair info: Change collation for oc_talk_rooms ...
Repair info: Change row format for oc_talk_sessions ...
Repair info: Change collation for oc_talk_sessions ...
Repair info: Change row format for oc_text_documents ...
Repair info: Change collation for oc_text_documents ...
Repair info: Change row format for oc_text_sessions ...
Repair info: Change collation for oc_text_sessions ...
Repair info: Change row format for oc_text_steps ...
Repair info: Change collation for oc_text_steps ...
Repair info: Change row format for oc_timemanager_client ...
Repair info: Change collation for oc_timemanager_client ...
Repair info: Change row format for oc_timemanager_commit ...
Repair info: Change collation for oc_timemanager_commit ...
Repair info: Change row format for oc_timemanager_project ...
Repair info: Change collation for oc_timemanager_project ...
Repair info: Change row format for oc_timemanager_share ...
Repair info: Change collation for oc_timemanager_share ...
Repair info: Change row format for oc_timemanager_task ...
Repair info: Change collation for oc_timemanager_task ...
Repair info: Change row format for oc_timemanager_time ...
Repair info: Change collation for oc_timemanager_time ...
Repair info: Change row format for oc_timetracker_client ...
Repair info: Change collation for oc_timetracker_client ...
Repair info: Change row format for oc_timetracker_goal ...
Repair info: Change collation for oc_timetracker_goal ...
Repair info: Change row format for oc_timetracker_project ...
Repair info: Change collation for oc_timetracker_project ...
Repair info: Change row format for oc_timetracker_tag ...
Repair info: Change collation for oc_timetracker_tag ...
Repair info: Change row format for oc_timetracker_timeline ...
Repair info: Change collation for oc_timetracker_timeline ...
Repair info: Change row format for oc_timetracker_timeline_entry ...
Repair info: Change collation for oc_timetracker_timeline_entry ...
Repair info: Change row format for oc_timetracker_user_to_client ...
Repair info: Change collation for oc_timetracker_user_to_client ...
Repair info: Change row format for oc_timetracker_user_to_project ...
Repair info: Change collation for oc_timetracker_user_to_project ...
Repair info: Change row format for oc_timetracker_work_interval ...
Repair info: Change collation for oc_timetracker_work_interval ...
Repair info: Change row format for oc_trusted_servers ...
Repair info: Change collation for oc_trusted_servers ...
Repair info: Change row format for oc_twofactor_backupcodes ...
Repair info: Change collation for oc_twofactor_backupcodes ...
Repair info: Change row format for oc_twofactor_nextcloud_notification_tokens ...
Repair info: Change collation for oc_twofactor_nextcloud_notification_tokens ...
Repair info: Change row format for oc_twofactor_providers ...
Repair info: Change collation for oc_twofactor_providers ...
Repair info: Change row format for oc_user_status ...
Repair info: Change collation for oc_user_status ...
Repair info: Change row format for oc_user_transfer_owner ...
Repair info: Change collation for oc_user_transfer_owner ...
Repair info: Change row format for oc_users ...
Repair info: Change collation for oc_users ...
Repair info: Change row format for oc_vcategory ...
Repair info: Change collation for oc_vcategory ...
Repair info: Change row format for oc_vcategory_to_object ...
Repair info: Change collation for oc_vcategory_to_object ...
Repair info: Change row format for oc_webauthn ...
Repair info: Change collation for oc_webauthn ...
Repair info: Change row format for oc_whats_new ...
Repair info: Change collation for oc_whats_new ...
Repair info: Change row format for oc_audioplayer_playlist_tracks ...
Repair info: Change collation for oc_audioplayer_playlist_tracks ...
Repair info: Change row format for oc_bookmarks_shared_to_shares ...
Repair info: Change collation for oc_bookmarks_shared_to_shares ...
Repair info: Change row format for oc_cospend_bill_owers ...
Repair info: Change collation for oc_cospend_bill_owers ...
Repair info: Change row format for oc_deck_assigned_labels ...
Repair info: Change collation for oc_deck_assigned_labels ...
Repair info: Change row format for oc_maps_device_points ...
Repair info: Change collation for oc_maps_device_points ...
Repair info: Change row format for oc_timetracker_lpa_tags ...
Repair info: Change collation for oc_timetracker_lpa_tags ...
Repair info: Change row format for oc_timetracker_workint_to_tag ...
Repair info: Change collation for oc_timetracker_workint_to_tag ...
Repair step: Repair SQLite autoincrement
Repair step: Copy data from accounts table when migrating from ownCloud
Repair step: Drop account terms table when migrating from ownCloud
Updating database schema
Updated database
Repair step: Check System Requirements
Repair step: Repair Passwords Database Objects
Updated "passwords" to 2022.12.11
Update app "richdocuments" from App Store
Update app "spreed" from App Store
Repair step: Fix the namespace in database tables
Update app "tasks" from App Store
Update app "timemanager" from App Store
Update app "timetracker" from App Store
Update app "twofactor_email" from App Store
Update app "unsplash" from App Store
The update was unsuccessful. Please report this issue to the Nextcloud community.
PASTE HERE
PASTE HERE
PASTE HERE
{"reqId":"LP1KqWPcPAddETJyytSs","level":0,"time":"2023-02-19T05:08:17+00:00","remoteAddr":"47.221.217.173","user":"--","app":"updater","method":"GET","url":"/fs/core/ajax/update.php?requesttoken=gI7ptPbgi%2Fqm%2FbfU3fOcj3%2BVwibPBz0Y9NfPSnL%2F0Eg%3D%3A5cen%2BZqR7JTnttih7YqvyE%2Fjj02eU0QqmfiICzqWnS0%3D","message":"\\OC\\Updater::checkAppStoreApp: Checked for update of app \"workflowengine\" in appstore","userAgent":"Mozilla/5.0 (Linux; Android 13) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"LP1KqWPcPAddETJyytSs","level":3,"time":"2023-02-19T05:08:17+00:00","remoteAddr":"47.221.217.173","user":"--","app":"no app in context","method":"GET","url":"/fs/core/ajax/update.php?requesttoken=gI7ptPbgi%2Fqm%2FbfU3fOcj3%2BVwibPBz0Y9NfPSnL%2F0Eg%3D%3A5cen%2BZqR7JTnttih7YqvyE%2Fjj02eU0QqmfiICzqWnS0%3D","message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 2013 Lost connection to MySQL server during query","userAgent":"Mozilla/5.0 (Linux; Android 13) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36","version":"24.0.1.1","exception":{"Exception":"Doctrine\\DBAL\\Exception\\DriverException","Message":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 2013 Lost connection to MySQL server during query","Code":2013,"Trace":[{"file":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Connection.php","line":1780,"function":"convert","class":"Doctrine\\DBAL\\Driver\\API\\MySQL\\ExceptionConverter","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},{"__class__":"Doctrine\\DBAL\\Query"}]},{"file":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Connection.php","line":1719,"function":"handleDriverException","class":"Doctrine\\DBAL\\Connection","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},{"__class__":"Doctrine\\DBAL\\Query"}]},{"file":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Connection.php","line":1067,"function":"convertExceptionDuringQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":[{"__class__":"Doctrine\\DBAL\\Driver\\PDO\\Exception"},"SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `permissions`, `checksum`, `metadata_etag`, `creation_time`, `upload_time` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` WHERE (`storage` = ?) AND (`path_hash` = ?)",[1,"e6231b09bfa1ca71e7eb51602e6101e8"],[1,2]]},{"file":"/home/serenity/public_html/fs/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `permissions`, `checksum`, `metadata_etag`, `creation_time`, `upload_time` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` WHERE (`storage` = ?) AND (`path_hash` = ?)",[1,"e6231b09bfa1ca71e7eb51602e6101e8"],[1,2],null]},{"file":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `permissions`, `checksum`, `metadata_etag`, `creation_time`, `upload_time` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` WHERE (`storage` = :dcValue1) AND (`path_hash` = :dcValue2)",{"dcValue1":1,"dcValue2":"e6231b09bfa1ca71e7eb51602e6101e8"},{"dcValue1":1,"dcValue2":2}]},{"file":"/home/serenity/public_html/fs/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Cache/Cache.php","line":165,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/home/serenity/public_html/fs/lib/private/Files/View.php","line":1339,"function":"get","class":"OC\\Files\\Cache\\Cache","type":"->","args":["appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Files/View.php","line":1390,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->","args":[{"__class__":"OC\\Files\\Storage\\LocalRootStorage"},"appdata_oc2bukigslc6/css/icons","/appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Node/Root.php","line":205,"function":"getFileInfo","class":"OC\\Files\\View","type":"->","args":["/appdata_oc2bukigslc6/css/icons"]},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["/appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Node/LazyFolder.php","line":72,"function":"call_user_func_array","args":[[{"__class__":"OC\\Files\\Node\\Root"},"get"],["appdata_oc2bukigslc6/css/icons"]]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Node/LazyFolder.php","line":149,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["get",["appdata_oc2bukigslc6/css/icons"]]},{"file":"/home/serenity/public_html/fs/lib/private/Files/AppData/AppData.php","line":141,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Template/IconsCacher.php","line":81,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["icons"]},{"function":"__construct","class":"OC\\Template\\IconsCacher","type":"->","args":[{"__class__":"OC\\Log\\PsrLoggerAdapter"},{"__class__":"OC\\Files\\AppData\\Factory"},{"__class__":"OC\\URLGenerator","userSession":{"__class__":"OC\\User\\Session"}},{"__class__":"OC\\AppFramework\\Utility\\TimeFactory"}]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"newInstanceArgs","class":"ReflectionClass","type":"->","args":[[{"__class__":"OC\\Log\\PsrLoggerAdapter"},{"__class__":"OC\\Files\\AppData\\Factory"},{"__class__":"OC\\URLGenerator","userSession":{"__class__":"OC\\User\\Session"}},{"__class__":"OC\\AppFramework\\Utility\\TimeFactory"}]]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"__class__":"ReflectionClass","name":"OC\\Template\\IconsCacher"}]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\IconsCacher"]},{"file":"/home/serenity/public_html/fs/lib/private/ServerContainer.php","line":161,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\IconsCacher",true]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":89,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Template\\IconsCacher",true]},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"array_map","args":[{"__class__":"Closure"},[{"__class__":"ReflectionParameter","name":"logger"},{"__class__":"ReflectionParameter","name":"appDataFactory"},{"__class__":"ReflectionParameter","name":"urlGenerator"},{"__class__":"ReflectionParameter","name":"config"},{"__class__":"ReflectionParameter","name":"defaults"},{"__class__":"ReflectionParameter","name":"serverRoot"},{"__class__":"ReflectionParameter","name":"cacheFactory"},"*** sensitive parameter replaced ***",{"__class__":"ReflectionParameter","name":"timeFactory"},{"__class__":"ReflectionParameter","name":"appConfig"}]]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"__class__":"ReflectionClass","name":"OC\\Template\\SCSSCacher"}]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\SCSSCacher"]},{"file":"/home/serenity/public_html/fs/lib/private/ServerContainer.php","line":161,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\SCSSCacher",true]},{"file":"/home/serenity/public_html/fs/lib/private/Repair.php","line":197,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Template\\SCSSCacher"]},{"file":"/home/serenity/public_html/fs/lib/private/Updater.php","line":292,"function":"getRepairSteps","class":"OC\\Repair","type":"::","args":[]},{"file":"/home/serenity/public_html/fs/lib/private/Updater.php","line":133,"function":"doUpgrade","class":"OC\\Updater","type":"->","args":["24.0.1.1","24.0.1.1"]},{"file":"/home/serenity/public_html/fs/core/ajax/update.php","line":194,"function":"upgrade","class":"OC\\Updater","type":"->","args":[]}],"File":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Driver/API/MySQL/ExceptionConverter.php","Line":114,"Previous":{"Exception":"Doctrine\\DBAL\\Driver\\PDO\\Exception","Message":"SQLSTATE[HY000]: General error: 2013 Lost connection to MySQL server during query","Code":2013,"Trace":[{"file":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":94,"function":"new","class":"Doctrine\\DBAL\\Driver\\PDO\\Exception","type":"::","args":[{"__class__":"PDOException","errorInfo":["HY000",2013,"Lost connection to MySQL server during query"]}]},{"file":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Connection.php","line":1057,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/home/serenity/public_html/fs/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `permissions`, `checksum`, `metadata_etag`, `creation_time`, `upload_time` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` WHERE (`storage` = ?) AND (`path_hash` = ?)",[1,"e6231b09bfa1ca71e7eb51602e6101e8"],[1,2],null]},{"file":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `permissions`, `checksum`, `metadata_etag`, `creation_time`, `upload_time` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` WHERE (`storage` = :dcValue1) AND (`path_hash` = :dcValue2)",{"dcValue1":1,"dcValue2":"e6231b09bfa1ca71e7eb51602e6101e8"},{"dcValue1":1,"dcValue2":2}]},{"file":"/home/serenity/public_html/fs/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Cache/Cache.php","line":165,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/home/serenity/public_html/fs/lib/private/Files/View.php","line":1339,"function":"get","class":"OC\\Files\\Cache\\Cache","type":"->","args":["appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Files/View.php","line":1390,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->","args":[{"__class__":"OC\\Files\\Storage\\LocalRootStorage"},"appdata_oc2bukigslc6/css/icons","/appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Node/Root.php","line":205,"function":"getFileInfo","class":"OC\\Files\\View","type":"->","args":["/appdata_oc2bukigslc6/css/icons"]},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["/appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Node/LazyFolder.php","line":72,"function":"call_user_func_array","args":[[{"__class__":"OC\\Files\\Node\\Root"},"get"],["appdata_oc2bukigslc6/css/icons"]]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Node/LazyFolder.php","line":149,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["get",["appdata_oc2bukigslc6/css/icons"]]},{"file":"/home/serenity/public_html/fs/lib/private/Files/AppData/AppData.php","line":141,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Template/IconsCacher.php","line":81,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["icons"]},{"function":"__construct","class":"OC\\Template\\IconsCacher","type":"->","args":[{"__class__":"OC\\Log\\PsrLoggerAdapter"},{"__class__":"OC\\Files\\AppData\\Factory"},{"__class__":"OC\\URLGenerator","userSession":{"__class__":"OC\\User\\Session"}},{"__class__":"OC\\AppFramework\\Utility\\TimeFactory"}]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"newInstanceArgs","class":"ReflectionClass","type":"->","args":[[{"__class__":"OC\\Log\\PsrLoggerAdapter"},{"__class__":"OC\\Files\\AppData\\Factory"},{"__class__":"OC\\URLGenerator","userSession":{"__class__":"OC\\User\\Session"}},{"__class__":"OC\\AppFramework\\Utility\\TimeFactory"}]]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"__class__":"ReflectionClass","name":"OC\\Template\\IconsCacher"}]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\IconsCacher"]},{"file":"/home/serenity/public_html/fs/lib/private/ServerContainer.php","line":161,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\IconsCacher",true]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":89,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Template\\IconsCacher",true]},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"array_map","args":[{"__class__":"Closure"},[{"__class__":"ReflectionParameter","name":"logger"},{"__class__":"ReflectionParameter","name":"appDataFactory"},{"__class__":"ReflectionParameter","name":"urlGenerator"},{"__class__":"ReflectionParameter","name":"config"},{"__class__":"ReflectionParameter","name":"defaults"},{"__class__":"ReflectionParameter","name":"serverRoot"},{"__class__":"ReflectionParameter","name":"cacheFactory"},"*** sensitive parameter replaced ***",{"__class__":"ReflectionParameter","name":"timeFactory"},{"__class__":"ReflectionParameter","name":"appConfig"}]]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"__class__":"ReflectionClass","name":"OC\\Template\\SCSSCacher"}]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\SCSSCacher"]},{"file":"/home/serenity/public_html/fs/lib/private/ServerContainer.php","line":161,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\SCSSCacher",true]},{"file":"/home/serenity/public_html/fs/lib/private/Repair.php","line":197,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Template\\SCSSCacher"]},{"file":"/home/serenity/public_html/fs/lib/private/Updater.php","line":292,"function":"getRepairSteps","class":"OC\\Repair","type":"::","args":[]},{"file":"/home/serenity/public_html/fs/lib/private/Updater.php","line":133,"function":"doUpgrade","class":"OC\\Updater","type":"->","args":["24.0.1.1","24.0.1.1"]},{"file":"/home/serenity/public_html/fs/core/ajax/update.php","line":194,"function":"upgrade","class":"OC\\Updater","type":"->","args":[]}],"File":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Driver/PDO/Exception.php","Line":26,"Previous":{"Exception":"PDOException","Message":"SQLSTATE[HY000]: General error: 2013 Lost connection to MySQL server during query","Code":"HY000","Trace":[{"file":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","line":92,"function":"execute","class":"PDOStatement","type":"->","args":[null]},{"file":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Connection.php","line":1057,"function":"execute","class":"Doctrine\\DBAL\\Driver\\PDO\\Statement","type":"->","args":[]},{"file":"/home/serenity/public_html/fs/lib/private/DB/Connection.php","line":261,"function":"executeQuery","class":"Doctrine\\DBAL\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `permissions`, `checksum`, `metadata_etag`, `creation_time`, `upload_time` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` WHERE (`storage` = ?) AND (`path_hash` = ?)",[1,"e6231b09bfa1ca71e7eb51602e6101e8"],[1,2],null]},{"file":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Query/QueryBuilder.php","line":345,"function":"executeQuery","class":"OC\\DB\\Connection","type":"->","args":["SELECT `filecache`.`fileid`, `storage`, `path`, `path_hash`, `filecache`.`parent`, `name`, `mimetype`, `mimepart`, `size`, `mtime`, `storage_mtime`, `encrypted`, `etag`, `permissions`, `checksum`, `metadata_etag`, `creation_time`, `upload_time` FROM `oc_filecache` `filecache` LEFT JOIN `oc_filecache_extended` `fe` ON `filecache`.`fileid` = `fe`.`fileid` WHERE (`storage` = :dcValue1) AND (`path_hash` = :dcValue2)",{"dcValue1":1,"dcValue2":"e6231b09bfa1ca71e7eb51602e6101e8"},{"dcValue1":1,"dcValue2":2}]},{"file":"/home/serenity/public_html/fs/lib/private/DB/QueryBuilder/QueryBuilder.php","line":281,"function":"execute","class":"Doctrine\\DBAL\\Query\\QueryBuilder","type":"->","args":[]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Cache/Cache.php","line":165,"function":"execute","class":"OC\\DB\\QueryBuilder\\QueryBuilder","type":"->","args":[]},{"file":"/home/serenity/public_html/fs/lib/private/Files/View.php","line":1339,"function":"get","class":"OC\\Files\\Cache\\Cache","type":"->","args":["appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Files/View.php","line":1390,"function":"getCacheEntry","class":"OC\\Files\\View","type":"->","args":[{"__class__":"OC\\Files\\Storage\\LocalRootStorage"},"appdata_oc2bukigslc6/css/icons","/appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Node/Root.php","line":205,"function":"getFileInfo","class":"OC\\Files\\View","type":"->","args":["/appdata_oc2bukigslc6/css/icons"]},{"function":"get","class":"OC\\Files\\Node\\Root","type":"->","args":["/appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Node/LazyFolder.php","line":72,"function":"call_user_func_array","args":[[{"__class__":"OC\\Files\\Node\\Root"},"get"],["appdata_oc2bukigslc6/css/icons"]]},{"file":"/home/serenity/public_html/fs/lib/private/Files/Node/LazyFolder.php","line":149,"function":"__call","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["get",["appdata_oc2bukigslc6/css/icons"]]},{"file":"/home/serenity/public_html/fs/lib/private/Files/AppData/AppData.php","line":141,"function":"get","class":"OC\\Files\\Node\\LazyFolder","type":"->","args":["appdata_oc2bukigslc6/css/icons"]},{"file":"/home/serenity/public_html/fs/lib/private/Template/IconsCacher.php","line":81,"function":"getFolder","class":"OC\\Files\\AppData\\AppData","type":"->","args":["icons"]},{"function":"__construct","class":"OC\\Template\\IconsCacher","type":"->","args":[{"__class__":"OC\\Log\\PsrLoggerAdapter"},{"__class__":"OC\\Files\\AppData\\Factory"},{"__class__":"OC\\URLGenerator","userSession":{"__class__":"OC\\User\\Session"}},{"__class__":"OC\\AppFramework\\Utility\\TimeFactory"}]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"newInstanceArgs","class":"ReflectionClass","type":"->","args":[[{"__class__":"OC\\Log\\PsrLoggerAdapter"},{"__class__":"OC\\Files\\AppData\\Factory"},{"__class__":"OC\\URLGenerator","userSession":{"__class__":"OC\\User\\Session"}},{"__class__":"OC\\AppFramework\\Utility\\TimeFactory"}]]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"__class__":"ReflectionClass","name":"OC\\Template\\IconsCacher"}]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\IconsCacher"]},{"file":"/home/serenity/public_html/fs/lib/private/ServerContainer.php","line":161,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\IconsCacher",true]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":89,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Template\\IconsCacher",true]},{"function":"OC\\AppFramework\\Utility\\{closure}","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["*** sensitive parameters replaced ***"]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":108,"function":"array_map","args":[{"__class__":"Closure"},[{"__class__":"ReflectionParameter","name":"logger"},{"__class__":"ReflectionParameter","name":"appDataFactory"},{"__class__":"ReflectionParameter","name":"urlGenerator"},{"__class__":"ReflectionParameter","name":"config"},{"__class__":"ReflectionParameter","name":"defaults"},{"__class__":"ReflectionParameter","name":"serverRoot"},{"__class__":"ReflectionParameter","name":"cacheFactory"},"*** sensitive parameter replaced ***",{"__class__":"ReflectionParameter","name":"timeFactory"},{"__class__":"ReflectionParameter","name":"appConfig"}]]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":116,"function":"buildClass","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":[{"__class__":"ReflectionClass","name":"OC\\Template\\SCSSCacher"}]},{"file":"/home/serenity/public_html/fs/lib/private/AppFramework/Utility/SimpleContainer.php","line":133,"function":"resolve","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\SCSSCacher"]},{"file":"/home/serenity/public_html/fs/lib/private/ServerContainer.php","line":161,"function":"query","class":"OC\\AppFramework\\Utility\\SimpleContainer","type":"->","args":["OC\\Template\\SCSSCacher",true]},{"file":"/home/serenity/public_html/fs/lib/private/Repair.php","line":197,"function":"query","class":"OC\\ServerContainer","type":"->","args":["OC\\Template\\SCSSCacher"]},{"file":"/home/serenity/public_html/fs/lib/private/Updater.php","line":292,"function":"getRepairSteps","class":"OC\\Repair","type":"::","args":[]},{"file":"/home/serenity/public_html/fs/lib/private/Updater.php","line":133,"function":"doUpgrade","class":"OC\\Updater","type":"->","args":["24.0.1.1","24.0.1.1"]},{"file":"/home/serenity/public_html/fs/core/ajax/update.php","line":194,"function":"upgrade","class":"OC\\Updater","type":"->","args":[]}],"File":"/home/serenity/public_html/fs/3rdparty/doctrine/dbal/src/Driver/PDO/Statement.php","Line":92}},"CustomMessage":"An exception occurred while executing a query: SQLSTATE[HY000]: General error: 2013 Lost connection to MySQL server during query"}}
{"reqId":"LP1KqWPcPAddETJyytSs","level":3,"time":"2023-02-19T05:08:17+00:00","remoteAddr":"47.221.217.173","user":"--","app":"updater","method":"GET","url":"/fs/core/ajax/update.php?requesttoken=gI7ptPbgi%2Fqm%2FbfU3fOcj3%2BVwibPBz0Y9NfPSnL%2F0Eg%3D%3A5cen%2BZqR7JTnttih7YqvyE%2Fjj02eU0QqmfiICzqWnS0%3D","message":"\\OC\\Updater::failure: Doctrine\\DBAL\\Exception\\DriverException: An exception occurred while executing a query: SQLSTATE[HY000]: General error: 2013 Lost connection to MySQL server during query","userAgent":"Mozilla/5.0 (Linux; Android 13) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"LP1KqWPcPAddETJyytSs","level":3,"time":"2023-02-19T05:08:17+00:00","remoteAddr":"47.221.217.173","user":"--","app":"updater","method":"GET","url":"/fs/core/ajax/update.php?requesttoken=gI7ptPbgi%2Fqm%2FbfU3fOcj3%2BVwibPBz0Y9NfPSnL%2F0Eg%3D%3A5cen%2BZqR7JTnttih7YqvyE%2Fjj02eU0QqmfiICzqWnS0%3D","message":"\\OC\\Updater::updateEnd: Update failed","userAgent":"Mozilla/5.0 (Linux; Android 13) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"LP1KqWPcPAddETJyytSs","level":1,"time":"2023-02-19T05:08:17+00:00","remoteAddr":"47.221.217.173","user":"--","app":"updater","method":"GET","url":"/fs/core/ajax/update.php?requesttoken=gI7ptPbgi%2Fqm%2FbfU3fOcj3%2BVwibPBz0Y9NfPSnL%2F0Eg%3D%3A5cen%2BZqR7JTnttih7YqvyE%2Fjj02eU0QqmfiICzqWnS0%3D","message":"\\OC\\Updater::maintenanceActive: Maintenance mode is kept active","userAgent":"Mozilla/5.0 (Linux; Android 13) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36","version":"24.0.1.1"}
{"reqId":"LP1KqWPcPAddETJyytSs","level":1,"time":"2023-02-19T05:08:17+00:00","remoteAddr":"47.221.217.173","user":"--","app":"updater","method":"GET","url":"/fs/core/ajax/update.php?requesttoken=gI7ptPbgi%2Fqm%2FbfU3fOcj3%2BVwibPBz0Y9NfPSnL%2F0Eg%3D%3A5cen%2BZqR7JTnttih7YqvyE%2Fjj02eU0QqmfiICzqWnS0%3D","message":"\\OC\\Updater::resetLogLevel: Reset log level to Warning(2)","userAgent":"Mozilla/5.0 (Linux; Android 13) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/110.0.0.0 Safari/537.36","version":"24.0.1.1"}
