Thanks for reporting issues back to Nextcloud!
Note: This is the **issu…e tracker of Nextcloud**, please do NOT use this to get answers to your questions or get help for fixing your installation. This is a place to report bugs to developers, after your server has been debugged. You can find help debugging your system on our home user forums: https://help.nextcloud.com or, if you use Nextcloud in a large organization, ask our engineers on https://portal.nextcloud.com. See also https://nextcloud.com/support for support options.
Nextcloud is an open source project backed by Nextcloud GmbH. Most of our volunteers are home users and thus primarily care about issues that affect home users. Our paid engineers prioritize issues of our customers. If you are neither a home user nor a customer, consider paying somebody to fix your issue, do it yourself or become a customer.
Guidelines for submitting issues:
* Please search the existing issues first, it's likely that your issue was already reported or even fixed.
- Go to https://github.com/nextcloud and type any word in the top search/command bar. You probably see something like "We couldn’t find any repositories matching ..." then click "Issues" in the left navigation.
- You can also filter by appending e. g. "state:open" to the search string.
- More info on search syntax within github: https://help.github.com/articles/searching-issues
* This repository https://github.com/nextcloud/server/issues is *only* for issues within the Nextcloud Server code. This also includes the apps: files, encryption, external storage, sharing, deleted files, versions, LDAP, and WebDAV Auth
* SECURITY: Report any potential security bug to us via our HackerOne page (https://hackerone.com/nextcloud) following our security policy (https://nextcloud.com/security/) instead of filing an issue in our bug tracker.
* The issues in other components should be reported in their respective repositories: You will find them in our GitHub Organization (https://github.com/nextcloud/)
* You can also use the Issue Template app to prefill most of the required information: https://apps.nextcloud.com/apps/issuetemplate
### How to use GitHub
* Please use the 👍 [reaction](https://blog.github.com/2016-03-10-add-reactions-to-pull-requests-issues-and-comments/) to show that you are affected by the same issue.
* Please don't comment if you have no relevant information to add. It's just extra noise for everyone subscribed to this issue.
* Subscribe to receive notifications on status change and new comments.
### Steps to reproduce
1. Add a large folder (27 GB +) containing 11.000 pictures and videos in Nextcloud desktop.
2. Upload seems to run okay.
### Expected behaviour
Everything should run smoothly, no error message should appear in Nextcloud desktop. No file should be deleted.
### Actual behaviour
"File is empty, although server reported x size" message appears in Nextcloud desktop. File is removed locally in my computer but exists in the server.
### Server configuration
**Operating system:** Debian 10
**Web server:** apache2
**Database:** PostgreSQL
**PHP version:** 7.4.X
**Nextcloud version:** 19.0.0 (but pretty sure it existed also in 18.0.X)
**Updated from an older Nextcloud/ownCloud or fresh install:** fresh install (but pretty sure it existed too on my last installation upgraded from 18 to 19).
**Where did you install Nextcloud from:**
**Signing status:**
<details>
<summary>Signing status</summary>
No errors have been found.
</details>
**List of activated apps:**
<details>
<summary>App list</summary>
- accessibility: 1.5.0
- activity: 2.12.0
- bruteforcesettings: 1.6.0
- calendar: 2.0.3
- cloud_federation_api: 1.2.0
- comments: 1.9.0
- contacts: 3.3.0
- contactsinteraction: 1.0.0
- dav: 1.15.0
- encryption: 2.7.0
- federatedfilesharing: 1.9.0
- federation: 1.9.0
- files: 1.14.0
- files_pdfviewer: 1.8.0
- files_rightclick: 0.16.0
- files_sharing: 1.11.0
- files_trashbin: 1.9.0
- files_versions: 1.12.0
- files_videoplayer: 1.8.0
- firstrunwizard: 2.8.0
- logreader: 2.4.0
- lookup_server_connector: 1.7.0
- mail: 1.4.0
- nextcloud_announcements: 1.8.0
- notifications: 2.7.0
- oauth2: 1.7.0
- password_policy: 1.9.1
- photos: 1.1.0
- privacy: 1.3.0
- provisioning_api: 1.9.0
- recommendations: 0.7.0
- richdocuments: 3.7.3
- richdocumentscode: 4.2.503
- serverinfo: 1.9.0
- settings: 1.1.0
- sharebymail: 1.9.0
- spreed: 9.0.1
- support: 1.2.1
- survey_client: 1.7.0
- systemtags: 1.9.0
- tasks: 0.13.1
- text: 3.0.1
- theming: 1.10.0
- twofactor_backupcodes: 1.8.0
- updatenotification: 1.9.0
- viewer: 1.3.0
- workflowengine: 2.1.0
- admin_audit
- files_external
- user_ldap
</details>
**Nextcloud configuration:**
<details>
<summary>Config report</summary>
"htaccess.RewriteBase": "\/",
"redis": {
"port": 6379
"apps_paths": [
"url": "\/apps",
"writable": false
"url": "\/custom_apps",
"writable": true
"nextcloud.nealta.fr"
"objectstore": {
"class": "\\OC\\Files\\ObjectStore\\S3",
"arguments": {
"bucket": "nealta-nextcloud-data",
"autocreate": true,
"key": "***REMOVED SENSITIVE VALUE***",
"hostname": "s3.nl-ams.scw.cloud",
"port": 443,
"use_ssl": true,
"region": "nl-ams"
"dbtype": "pgsql",
"version": "19.0.0.12",
"overwrite.cli.url": "https:\/\/nextcloud.nealta.fr",
"overwritehost": "nextcloud.nealta.fr",
"overwriteprotocol": "https",
"mail_smtpmode": "smtp",
"mail_smtpsecure": "tls",
"mail_sendmailmode": "smtp",
"mail_smtpauth": 1,
"mail_smtpauthtype": "PLAIN",
"mail_smtpport": "587",
"dbport": "",
"installed": true
</details>
**Are you using external storage, if yes which one:**
S3 is used as backend system. But on my previous installation I had the same problem with a SFTP external storage.
**Are you using encryption:** yes
**Are you using an external user-backend, if yes which one:** no
### Client configuration
**Browser:** Firefox 77
**Operating system:** Fedora
### Logs
#### Web server error log
<details>
<summary>Web server error log</summary>
Can't find any relevant log
</details>
#### Nextcloud log (data/nextcloud.log)
<details>
<summary>Nextcloud log</summary>
[no app in context] Error: Couldn't re-calculate unencrypted size for files/Photos/0000 - Numérisations/Numérisations/NUM1161.jpeg
GET /remote.php/dav/files/xxx/Photos/0000%20-%20Num%C3%A9risations/Num%C3%A9risations/NUM1161.jpeg
from 82.XX.64.XXX by xxx at 2020-07-04T18:57:31+00:00
[webdav] Fatal: Sabre\DAV\Exception\BadRequest: Expected filesize of 293879 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 229376 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. at <<closure>>
0. /var/www/html/apps/dav/lib/Connector/Sabre/Directory.php line 154
OCA\DAV\Connector\Sabre\File->put(null)
1. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 1104
OCA\DAV\Connector\Sabre\Directory->createFile("NUM739.jpg", null)
2. /var/www/html/3rdparty/sabre/dav/lib/DAV/CorePlugin.php line 527
Sabre\DAV\Server->createFile("files/xxx/P ... g", null, null)
3. /var/www/html/3rdparty/sabre/event/lib/WildcardEmitterTrait.php line 89
Sabre\DAV\CorePlugin->httpPut(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
4. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 474
Sabre\DAV\Server->emit("method:PUT", [Sabre\HTTP\Requ ... }])
5. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 251
Sabre\DAV\Server->invokeMethod(Sabre\HTTP\Request {}, Sabre\HTTP\Response {})
6. /var/www/html/3rdparty/sabre/dav/lib/DAV/Server.php line 319
Sabre\DAV\Server->start()
7. /var/www/html/apps/dav/lib/Server.php line 320
Sabre\DAV\Server->exec()
8. /var/www/html/apps/dav/appinfo/v2/remote.php line 35
OCA\DAV\Server->exec()
9. /var/www/html/remote.php line 167
require_once("/var/www/html/a ... p")
PUT /remote.php/dav/files/xxx/Photos/0000%20-%20Num%C3%A9risations/Num%C3%A9risations/NUM739.jpg
from 82.XX.64.XXX by xxx at 2020-07-04T18:55:51+00:00
[webdav] Fatal: Sabre\DAV\Exception\BadRequest: Expected filesize of 314560 bytes but read (from Nextcloud client) and wrote (to Nextcloud storage) 0 bytes. Could either be a network problem on the sending side or a problem writing to the storage on the server side. at <<closure>>
OCA\DAV\Connector\Sabre\Directory->createFile("NUM744.jpg", null)
PUT /remote.php/dav/files/xxx/Photos/0000%20-%20Num%C3%A9risations/Num%C3%A9risations/NUM744.jpg
from 82.XX.64.XXX by xxx at 2020-07-04T18:59:19+00:00
</details>
#### Browser log
<details>
<summary>Browser log</summary>
</details>
Strange thing is that I don't have this problem with any other synced folder.
Thank you !
