Hi all,
Iāve been running NextCloud for a few years now, and just migrated to the AIO solution for better management and updates etc.
However, the AIO is giving me slow performance issues.
When navigating the web interface (i.e. just clicking between folders, or menus etc within the web interface) - every few minutes it will āstallā and just display the grey spinning wheel trying to load for about 30 seconds. Once it has loaded, I get around 2 - 3 mins of snappy/normal speed while navigating, but then I have to wait another 30 seconds ish for it to load.
Has anyone else experienced this?
Downloads from the server are fine, and Iām receiving a constant 300Mbps, no issues there.
Uploads, however, seem to not go faster than 40 - 45Mbps (can achieve triple this via the non-docker solution).
Iām running the latest stable version of the AIO (1.5.0)
This is running on Ubuntu Server 22.04
Docker version 20.10.12
Iāve increased the specs of the server to double of my previous Nextcloud setup (4GB RAM), however it didnāt help. RAM and CPU usage are sitting low on the server.
Iām not sure if itās related, but I am using an alternative path for my NextCloud Data directory. I have it mounted to a secondary HDD, which is an internal HDD on the same server.
If I look in Administration > System, it says my mount point is ā/mnt/ncdataā, which is not correct. However it does correctly pick up the size and usage of the disk.
My thinking was Nextcloud might be getting confused about the Data Dir, taking a while before figuring out itās not mounted there? But just a guess.
