AIO Slim Error /nextcloud-aio/connect ; failed to add interface
i try to install the AIO-mastercontainer with his own ip when i can run it but after the password generation i get a slim Error and i’m unable to find a solution.
They installation generate this network.
NOTICE: PHP message: Slim Application Error
Type: GuzzleHttp\Exception\ServerException
Code: 500
Message: Server error: POST http://localhost/v1.41/networks/nextcloud-aio/connect resulted in a 500 Internal Server Error response:
{"message":"failed to add interface veth3bf20b9 to sandbox: error setting interface "veth3bf20b9" IP to 172.21.0.2/16: (truncated…)
File: /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Exception/RequestException.php
Line: 113
Trace: #0 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Middleware.php(72): GuzzleHttp\Exception\RequestException::create(Object(GuzzleHttp\Psr7\Request), Object(GuzzleHttp\Psr7\Response), NULL, Array, NULL)
#1 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(209): GuzzleHttp\Middleware::GuzzleHttp{closure}(Object(GuzzleHttp\Psr7\Response))
#2 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(158): GuzzleHttp\Promise\Promise::callHandler(1, Object(GuzzleHttp\Psr7\Response), NULL)
#3 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/TaskQueue.php(52): GuzzleHttp\Promise\Promise::GuzzleHttp\Promise{closure}()
#4 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(251): GuzzleHttp\Promise\TaskQueue->run(true)
#5 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(227): GuzzleHttp\Promise\Promise->invokeWaitFn()
#6 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(272): GuzzleHttp\Promise\Promise->waitIfPending()
#7 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(229): GuzzleHttp\Promise\Promise->invokeWaitList()
#8 /var/www/docker-aio/php/vendor/guzzlehttp/promises/src/Promise.php(69): GuzzleHttp\Promise\Promise->waitIfPending()
#9 /var/www/docker-aio/php/vendor/guzzlehttp/guzzle/src/Client.php(189): GuzzleHttp\Promise\Promise->wait()
#10 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(868): GuzzleHttp\Client->request(‘POST’, ‘http://localhos…’, Array)
#11 /var/www/docker-aio/php/src/Docker/DockerActionManager.php(887): AIO\Docker\DockerActionManager->ConnectContainerIdToNetwork(‘nextcloud-aio-m…’, ‘’)
#12 /var/www/docker-aio/php/public/index.php(83): AIO\Docker\DockerActionManager->ConnectMasterContainerToNetwork()
#13 /var/www/docker-aio/php/vendor/slim/slim/Slim/Handlers/Strategies/RequestResponse.php(38): Closure->{closure}(Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#14 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(358): Slim\Handlers\Strategies\RequestResponse->__invoke(Object(Closure), Object(GuzzleHttp\Psr7\ServerRequest), Object(GuzzleHttp\Psr7\Response), Array)
#15 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Slim\Routing\Route->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#16 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#17 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/Route.php(315): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#18 /var/www/docker-aio/php/vendor/slim/slim/Slim/Routing/RouteRunner.php(68): Slim\Routing\Route->run(Object(GuzzleHttp\Psr7\ServerRequest))
#19 /var/www/docker-aio/php/vendor/slim/csrf/src/Guard.php(482): Slim\Routing\RouteRunner->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#20 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(168): Slim\Csrf\Guard->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Slim\Routing\RouteRunner))
#21 /var/www/docker-aio/php/vendor/slim/twig-view/src/TwigMiddleware.php(115): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#22 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Views\TwigMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#23 /var/www/docker-aio/php/src/Middleware/AuthMiddleware.php(38): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#24 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(269): AIO\Middleware\AuthMiddleware->__invoke(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#25 /var/www/docker-aio/php/vendor/slim/slim/Slim/Middleware/ErrorMiddleware.php(76): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#26 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(121): Slim\Middleware\ErrorMiddleware->process(Object(GuzzleHttp\Psr7\ServerRequest), Object(Psr\Http\Server\RequestHandlerInterface@anonymous))
#27 /var/www/docker-aio/php/vendor/slim/slim/Slim/MiddlewareDispatcher.php(65): Psr\Http\Server\RequestHandlerInterface@anonymous->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#28 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(199): Slim\MiddlewareDispatcher->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#29 /var/www/docker-aio/php/vendor/slim/slim/Slim/App.php(183): Slim\App->handle(Object(GuzzleHttp\Psr7\ServerRequest))
#30 /var/www/docker-aio/php/public/index.php(185): Slim\App->run()
#31 {main}
Tips: To display error details in HTTP response set “displayErrorDetails” to true in the ErrorHandler constructor.
Hi, can you post the docker run command or the docker-compose file here that you used?
Yes of course,
docker run --init --name nextcloud-aio-mastercontainer --network ipvlan_net --ip 10.10.10.1 --restart always --volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config --volume /var/run/docker.sock:/var/run/docker.sock:ro nextcloud/all-in-one:latest
Can you remove this from the docker run command and try again?
i need this ip but for troubleshooting i try it direkt in the host with this follow run-command but i have every time the same problem, i get the password and can enter it but then i get this Error.
docker run --init --sig-proxy=false --name nextcloud-aio-mastercontainer --restart always --publish 80:80 --publish 8080:8080 --publish 8443:8443 --volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config --volume /var/run/docker.sock:/var/run/docker.sock:ro nextcloud/all-in-one:latest
What error are you running into if you use this command and open https://ip.address.of.server:8080 ?
by all try’s i stuck on this place after entering Password
A website error has occurred. Sorry for the temporary inconvenience.
Go Back http://10.10.10.10:8000/containers#
I see. Can you post the output of sudo docker logs nextcloud-aio-mastercontainer here then?
[root@akane ~]# docker logs nextcloud-aio-mastercontainer
Trying to fix docker.sock permissions internally…
Creating docker group internally with id 990
Initial startup of Nextcloud All-in-One complete!
You should be able to open the Nextcloud AIO Interface now on port 8080 of this server!
E.g. https://internal.ip.of.this.server:8080
If your server has port 80 and 8443 open and you point a domain to your server, you can get a valid certificate automatically by opening the Nextcloud AIO Interface via:
https://your-domain-that-points-to-this-server.tld:8443
[Sat Feb 10 12:24:26.547895 2024] [mpm_event:notice] [pid 137:tid 140354315012936] AH00489: Apache/2.4.58 (Unix) OpenSSL/3.1.4 configured – resuming normal operations
[Sat Feb 10 12:24:26.547961 2024] [core:notice] [pid 137:tid 140354315012936] AH00094: Command line: ‘httpd -D FOREGROUND’
[10-Feb-2024 12:24:26] NOTICE: fpm is running, pid 143
[10-Feb-2024 12:24:26] NOTICE: ready to handle connections
{“level”:“info”,“ts”:1707567866.55243,“msg”:“using provided configuration”,“config_file”:“/Caddyfile”,“config_adapter”:“”}
Code: 500
{"message":"failed to set gateway while updating gateway: file exists"}
Line: 113
#31 {main}
And the Error repeats when i try it
Hm… can you try again with the following command?
docker run --init --sig-proxy=false --name nextcloud-aio-mastercontainer --restart always --publish 80:80 --publish 8080:8080 --publish 8443:8443 --network bridge --volume nextcloud_aio_mastercontainer:/mnt/docker-aio-config --volume /var/run/docker.sock:/var/run/docker.sock:ro nextcloud/all-in-one:latest
Thats really interesting, i can open only over Port 8000, but this time i can start the configuration. Normal without the --network tag its using the bridge network a other different i can not see in the run code
Thank You :slight_smile:
But can u explain me why the AIO problems with his own ip over the ipvlan have?
