Since tonight, I guess after the daily backup, the AIO apache container did not work anymore. Checking its state it tells “created”.
docker inspect nextcloud-aio-apache
"Id": "32317764e2d8dc681c0ec65ee5a00a417f1a82a2e22ef32b137d5e0e50c16fc4",
"Created": "2023-08-22T02:45:28.072232759Z",
"Path": "/start.sh",
"Args": [
"/usr/bin/supervisord",
"-c",
"/supervisord.conf"
"State": {
"Status": "created",
"Running": false,
"Paused": false,
"Restarting": false,
"OOMKilled": false,
"Dead": false,
"Pid": 0,
"ExitCode": 128,
"Error": "driver failed programming external connectivity on endpoint nextcloud-aio-apache (5aef47796940b8ef58acd84eb2170a8819cb3936045db996aa63dcdc8823792d): (iptables failed: iptables --wait -t nat -A DOCKER -p tcp -d 0/0 --dport 443 -j DNAT --to-destination 172.19.0.8:443 ! -i br-09118e3649c1: iptables: No chain/target/match by that name.\n (exit status 1))",
"StartedAt": "0001-01-01T00:00:00Z",
"FinishedAt": "0001-01-01T00:00:00Z"
"Image": "sha256:a77cf3dec4110a506b2511515cea91b3c87e16c682098e437d2503890be49d1f",
"ResolvConfPath": "/var/lib/docker/containers/32317764e2d8dc681c0ec65ee5a00a417f1a82a2e22ef32b137d5e0e50c16fc4/resolv.conf",
"HostnamePath": "",
"HostsPath": "/var/lib/docker/containers/32317764e2d8dc681c0ec65ee5a00a417f1a82a2e22ef32b137d5e0e50c16fc4/hosts",
"LogPath": "",
"Name": "/nextcloud-aio-apache",
"RestartCount": 0,
"Driver": "overlay2",
"Platform": "linux",
"MountLabel": "",
"ProcessLabel": "",
"AppArmorProfile": "",
"ExecIDs": null,
"HostConfig": {
"Binds": [
"nextcloud_aio_nextcloud:/var/www/html:ro",
"nextcloud_aio_apache:/mnt/data:rw"
"ContainerIDFile": "",
"LogConfig": {
"Type": "json-file",
"Config": {
"max-file": "5",
"max-size": "10m"
"NetworkMode": "nextcloud-aio",
"PortBindings": {
"443/tcp": [
"HostIp": "",
"HostPort": "443"
"443/udp": [
"HostIp": "",
"HostPort": "443"
"RestartPolicy": {
"Name": "unless-stopped",
"MaximumRetryCount": 0
"AutoRemove": false,
"VolumeDriver": "",
"VolumesFrom": null,
"ConsoleSize": [
0,
0
"CapAdd": null,
"CapDrop": null,
"CgroupnsMode": "host",
"Dns": null,
"DnsOptions": null,
"DnsSearch": null,
"ExtraHosts": null,
"GroupAdd": null,
"IpcMode": "private",
"Cgroup": "",
"Links": null,
"OomScoreAdj": 0,
"PidMode": "",
"Privileged": false,
"PublishAllPorts": false,
"ReadonlyRootfs": true,
"SecurityOpt": null,
"Tmpfs": {
"/home/www-data": "",
"/tmp": "",
"/usr/local/apache2/logs": "",
"/var/log/supervisord": "",
"/var/run/supervisord": ""
"UTSMode": "",
"UsernsMode": "",
"ShmSize": 67108864,
"Runtime": "runc",
"Isolation": "",
"CpuShares": 0,
"Memory": 0,
"NanoCpus": 0,
"CgroupParent": "",
"BlkioWeight": 0,
"BlkioWeightDevice": null,
"BlkioDeviceReadBps": null,
"BlkioDeviceWriteBps": null,
"BlkioDeviceReadIOps": null,
"BlkioDeviceWriteIOps": null,
"CpuPeriod": 0,
"CpuQuota": 0,
"CpuRealtimePeriod": 0,
"CpuRealtimeRuntime": 0,
"CpusetCpus": "",
"CpusetMems": "",
"Devices": null,
"DeviceCgroupRules": null,
"DeviceRequests": null,
"MemoryReservation": 0,
"MemorySwap": 0,
"MemorySwappiness": null,
"OomKillDisable": false,
"PidsLimit": null,
"Ulimits": null,
"CpuCount": 0,
"CpuPercent": 0,
"IOMaximumIOps": 0,
"IOMaximumBandwidth": 0,
"MaskedPaths": [
"/proc/asound",
"/proc/acpi",
"/proc/kcore",
"/proc/keys",
"/proc/latency_stats",
"/proc/timer_list",
"/proc/timer_stats",
"/proc/sched_debug",
"/proc/scsi",
"/sys/firmware"
"ReadonlyPaths": [
"/proc/bus",
"/proc/fs",
"/proc/irq",
"/proc/sys",
"/proc/sysrq-trigger"
"GraphDriver": {
"Data": {
"LowerDir": "/var/lib/docker/overlay2/c02286e8327e6d94d18320c49f70d021dd00bddbda574729f2ec4d9df59a50a8-init/diff:/var/lib/docker/overlay2/1fa2acb45de1364fb852f255ee302ae678fea778a8dde6fe80c2e1090bc68d61/diff:/var/lib/docker/overlay2/cceab8191bfa400ea0fd4ec65a82cea2851d65ed6c11f2a1eb800f74b0ae7f2f/diff:/var/lib/docker/overlay2/b7e29d9f12e5336d483837a4ba157a8d9b9f985acb95ea6a3903c2da0276f869/diff:/var/lib/docker/overlay2/94a7600386c7b9e88c9c1355806d8c310cae3e2595a3fda3851dbd127bb01c03/diff:/var/lib/docker/overlay2/26b52bdeff8d783d04e0e6c8c14bef89984646bd7c7457db64a7870ec4aab95f/diff:/var/lib/docker/overlay2/c43d739c0fc10b891b56404049c77c18f66430fdaf972b88c2d19694f0751df5/diff:/var/lib/docker/overlay2/452a7a33031fc225b104f6a0360fc4e2ee2995ab348069a2af093e291f76a8e9/diff:/var/lib/docker/overlay2/c4c23983689d359b949bd92ec96e38bde11eb4cc8dc9a0574eb911ca8e8bd21e/diff:/var/lib/docker/overlay2/b24cd21df5940bd32420bdbb6afc85a7aed1b9e6883a8186e426a5c0623c2a4a/diff:/var/lib/docker/overlay2/996d817ff601979ff0a8c02a0fae724830e51a8623225814b795eb79924e2f74/diff:/var/lib/docker/overlay2/c8435876e7dbf4644513705d933d1b5c0a722709e903c74e141d3edcf723faff/diff:/var/lib/docker/overlay2/701370f641636873fd59f7fcbaedff6d055107decf2461a0f69837c05e9ac533/diff:/var/lib/docker/overlay2/76b1b46a34807eb176e0a892e1b2f250390faa91ffd20a5c09a60233bbd3dc41/diff",
"MergedDir": "/var/lib/docker/overlay2/c02286e8327e6d94d18320c49f70d021dd00bddbda574729f2ec4d9df59a50a8/merged",
"UpperDir": "/var/lib/docker/overlay2/c02286e8327e6d94d18320c49f70d021dd00bddbda574729f2ec4d9df59a50a8/diff",
"WorkDir": "/var/lib/docker/overlay2/c02286e8327e6d94d18320c49f70d021dd00bddbda574729f2ec4d9df59a50a8/work"
"Name": "overlay2"
"Mounts": [
"Type": "volume",
"Name": "nextcloud_aio_nextcloud",
"Source": "/var/lib/docker/volumes/nextcloud_aio_nextcloud/_data",
"Destination": "/var/www/html",
"Driver": "local",
"Mode": "ro",
"RW": false,
"Propagation": ""
"Type": "volume",
"Name": "nextcloud_aio_apache",
"Source": "/var/lib/docker/volumes/nextcloud_aio_apache/_data",
"Destination": "/mnt/data",
"Driver": "local",
"Mode": "rw",
"RW": true,
"Propagation": ""
"Config": {
"Hostname": "32317764e2d8",
"Domainname": "",
"User": "www-data",
"AttachStdin": false,
"AttachStdout": false,
"AttachStderr": false,
"ExposedPorts": {
"443/tcp": {},
"443/udp": {},
"80/tcp": {}
"Tty": false,
"OpenStdin": false,
"StdinOnce": false,
"Env": [
"NC_DOMAIN=yxc.selfhost.eu",
"NEXTCLOUD_HOST=nextcloud-aio-nextcloud",
"COLLABORA_HOST=nextcloud-aio-collabora",
"TALK_HOST=nextcloud-aio-talk",
"APACHE_PORT=443",
"ONLYOFFICE_HOST=nextcloud-aio-onlyoffice",
"TZ=Etc/UTC",
"APACHE_MAX_SIZE=10737418240",
"APACHE_MAX_TIME=3600",
"NOTIFY_PUSH_HOST=nextcloud-aio-notify-push",
"PATH=/usr/local/apache2/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin",
"HTTPD_PREFIX=/usr/local/apache2",
"HTTPD_VERSION=2.4.57",
"HTTPD_SHA256=dbccb84aee95e095edfbb81e5eb926ccd24e6ada55dcd83caecb262e5cf94d2a",
"HTTPD_PATCHES=rewrite-windows-testchar-h.patch 1d5620574fa03b483262dc5b9a66a6906553389952ab5d3070a02f887cc20193"
"Cmd": [
"-c",
"/supervisord.conf"
"Healthcheck": {
"Test": [
"CMD-SHELL",
"/healthcheck.sh"
"Image": "nextcloud/aio-apache:latest",
"Volumes": {
"/mnt/data": {}
"WorkingDir": "/usr/local/apache2",
"Entrypoint": [
"/start.sh"
"OnBuild": null,
"Labels": {
"com.centurylinklabs.watchtower.enable": "false"
"StopSignal": "SIGWINCH"
"NetworkSettings": {
"Bridge": "",
"SandboxID": "a153e4c6a2ce612421400490e8a4103232ea9ce484292d55dc386bace71a6409",
"HairpinMode": false,
"LinkLocalIPv6Address": "",
"LinkLocalIPv6PrefixLen": 0,
"Ports": {},
"SandboxKey": "/var/run/docker/netns/a153e4c6a2ce",
"SecondaryIPAddresses": null,
"SecondaryIPv6Addresses": null,
"EndpointID": "",
"Gateway": "",
"GlobalIPv6Address": "",
"GlobalIPv6PrefixLen": 0,
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"Networks": {
"nextcloud-aio": {
"IPAMConfig": null,
"Links": null,
"Aliases": [
"32317764e2d8"
"NetworkID": "09118e3649c160f7c59fd501b2d65c4d3390b8c0f79bc1c3d58cd3930062113f",
"EndpointID": "",
"Gateway": "",
"IPAddress": "",
"IPPrefixLen": 0,
"IPv6Gateway": "",
"MacAddress": "",
"DriverOpts": null
