Sorry, I don’t know the versions of the containers within AIO
AIO v11.0.0
Ubuntu 22.04.5 LTS
Apache v?
I will be using a Cloudflare tunnel
- PHP version (e.g, 8.3):
I don't know what this is
Yes
At first laungh
AIO docker container within a Linux VM on ProxMoxI am also trying to use a NFS share as the data directory
Yes, Cloudflare
When starting the AIO container from the web UI (IPAdd:8080), all containers will start except Apache, Nextcloud, and Notify Push.
- Within TrueNAS, I set ownership for the Nextcloud dataset to www-data(UID 33):root(GID 0), and access to 750. Both the TrueNAS system and the Ubuntu system have www-data UID and GID set as 33. I checked in the Ubuntu system and this all shows up correctly.
- With the configuration below, when I start the containers, I get 3 that won’t start. The first log entry is what I get for the Nextcloud container. (Sorry, I know there are more logs, but I don’t know where they are.)
- Seeing that this is a permissions issue, I tried setting the group to www-data(GID 33). No change
- I then set access to 777. I know this is bad. I just wanted to see if I could just get passed the issue. This gave me the second log entry. The permissions issue seems to have gone away, but it still won’t load the 3 containers.
- The solution that everyone seems to have luck with are the commands sudo chown -R 33:0 /mnt/ncdata && sudo chmod -R 750 /mnt/ncdata. These commands don’t work from the Ubuntu system as TrueNAS manages permissions, but as mentoned earlier, I did make sure this was set correctly.
2025-06-09T00:03:04.016549564Z Connection to nextcloud-aio-database (172.18.0.4) 5432 port [tcp/postgresql] succeeded!
2025-06-09T00:03:06.050479797Z now
2025-06-09T00:03:06.050528523Z -------------------------------
2025-06-09T00:03:06.050537126Z 2025-06-08 20:03:06.049429-04
2025-06-09T00:03:06.050544671Z (1 row)
2025-06-09T00:03:06.050551974Z
2025-06-09T00:03:06.059125640Z + '[' -f /dev-dri-group-was-added ']'
2025-06-09T00:03:06.059525607Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2025-06-09T00:03:06.060520190Z + '[' -n '' ']'
2025-06-09T00:03:06.060560767Z + set +x
2025-06-09T00:03:06.073936537Z chown: cannot read directory '/mnt/ncdata': Permission denied
2025-06-09T00:03:06.077085601Z chmod: changing permissions of '/mnt/ncdata': Operation not permitted
2025-06-09T00:03:06.077949924Z chmod: cannot read directory '/mnt/ncdata': Permission denied
2025-06-09T00:03:06.097236069Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2025-06-09T00:03:06.498178540Z The initial Nextcloud installation failed.
2025-06-09T00:03:06.498221560Z Please reset AIO properly and try again. For further clues what went wrong, check the logs above.
2025-06-09T00:03:06.498230335Z See https://github.com/nextcloud/all-in-one#how-to-properly-reset-the-instance
2025-06-09T00:04:08.135573041Z Connection to nextcloud-aio-database (172.18.0.4) 5432 port [tcp/postgresql] succeeded!
2025-06-09T00:04:10.172236392Z now
2025-06-09T00:04:10.172339104Z -------------------------------
2025-06-09T00:04:10.172349259Z 2025-06-08 20:04:10.171015-04
2025-06-09T00:04:10.172357255Z (1 row)
2025-06-09T00:04:10.172364978Z
2025-06-09T00:04:10.181068683Z + '[' -f /dev-dri-group-was-added ']'
2025-06-09T00:04:10.181537073Z ++ find /dev -maxdepth 1 -mindepth 1 -name dri
2025-06-09T00:04:10.182537093Z + '[' -n '' ']'
2025-06-09T00:04:10.182568833Z + set +x
2025-06-09T00:04:10.212039582Z Connection to nextcloud-aio-redis (172.18.0.3) 6379 port [tcp/redis] succeeded!
2025-06-09T00:04:10.585524110Z The initial Nextcloud installation failed.
2025-06-09T00:04:10.585583644Z Please reset AIO properly and try again. For further clues what went wrong, check the logs above.
2025-06-09T00:04:10.585595992Z See https://github.com/nextcloud/all-in-one#how-to-properly-reset-the-instance
I know there are other logs and useful information, but I don’t know where to find it. I will provide anything else I can if told how.
docker-compose.yml:
nextcloud:
image: ghcr.io/nextcloud-releases/all-in-one:latest
init: true
environment:
NEXTCLOUD_DATADIR: /mnt/nextcloud
SKIP_DOMAIN_VALIDATION: true
volumes:
ports:
- 80:80
- 8080:8080
- 8443:8443
restart: always
Unfortunately, my ISP uses CGNAT. My plan was to make Nextcloud accessible locally and use a Cloudflare tunnel to access from outside my house. It’s my understanding that I need the SKIP_DOMAIN_VALIDATION line to do this. I am also trying to use a NFS share from TrueNAS Core as my data directory, hence the NEXTCLOUD_DATADIR line. My share will only be accessible by Nextcloud.
