AIO: containers don't start after manual stop
    • 33.0.0
    • Debian Trixie VM
    • via AIO
    • caddy 2.11.2 in front of AIO
    • via AIO
    • yes
    • after installation
    • AIO
    • no
Fresh installation of AIO was working fine. But when stopping the containers (e.g. for borgbackup) in the AIO WebUI most containers won’t start up again (see pic). It seams like there is not even an attempt to start them. I can’t see errors in the master container a the non startet containers don’t even have any information in the logs (as they aren’t started…).
–> I have no clue, why this happens.
Reboot of the VM doesn’t fix it. The only way to get a working instance back (temporary) is to restore a VM snapshot (works as long as the containers are not stopped…)
This is the final state after starting the containers:
  1. With a fully working AIO instance to AIO WebUI in stop containers
  2. Wait for stopping to complete
  3. start containers
can't find meaningful logs, please advise where to look
PASTE
PASTE HERE
occ not working because Nextcloud container won't start up
Hi, can you please post the output of sudo docker inspect nextcloud-aio-mastercontainer here?
Ok, this is really embarrassing. I found the problem and it was my fault. I’ll leave this here just in case anyone has the same problem in the future.
As mentioned I have a caddy instance in front of AIO. In the caddyfile I specified for the AIO-Admininterface (as part of some general hardening… which turned out as too hard :smiley: ):
X-Frame-Options DENY
What I didn’t realise is that the AIO WebUI seams to rely on IFrames to start the containers. Replacing it with
X-Frame-Options SAMEORIGIN
fixed the issues.
All containers are starting up again. Problem solved :slight_smile:
