i have a Nextcloud on Version 20.07, upgraded from 15.x. The Cloud use Ldap and Database User at the same time.
After Upgrade to 20.07 i miss many users in the user Page. If i disable the ldap app, i can see all database user (round about 500). If i enable the ldap app, i only see 10 database user, 15 ldap user (160 users are in the cloud) and i cant set permissions, groups or Cloudsize on all non visible users.
I can login with non visible and visible users. Some Users cant upload files with “Unknown error” popup.
The apache Log doesnt show me errors.
Nextcloud i see: Error files Backends provided no user object for [USER X]
How i can solve this?
I tried:
- set new ldap config
- reboot server
- occ upgrade
- occ maintenance:repair
Infos:
PHP 7.4.3
Nextcloud 20.07 via web updater
MariaDB 10.3.25
- accessibility: 1.6.0
- activity: 2.13.4
- bruteforcesettings: 2.0.1
- cloud_federation_api: 1.3.0
- comments: 1.10.0
- contactsinteraction: 1.1.0
- dav: 1.16.2
- extract: 1.3.0
- federatedfilesharing: 1.10.2
- federation: 1.10.1
- files: 1.15.0
- files_external: 1.11.1
- files_pdfviewer: 2.0.1
- files_rightclick: 0.17.0
- files_sharing: 1.12.2
- files_trashbin: 1.10.1
- files_versions: 1.13.0
- firstrunwizard: 2.9.0
- logreader: 2.5.0
- lookup_server_connector: 1.8.0
- nextcloud_announcements: 1.9.0
- notifications: 2.8.0
- oauth2: 1.8.0
- occweb: 0.0.7
- password_policy: 1.10.1
- photos: 1.2.3
- privacy: 1.4.0
- provisioning_api: 1.10.0
- recommendations: 0.8.0
- serverinfo: 1.10.0
- settings: 1.2.0
- sharebymail: 1.10.0
- support: 1.3.0
- survey_client: 1.8.0
- systemtags: 1.10.0
- text: 3.1.0
- theming: 1.11.0
- twofactor_backupcodes: 1.9.0
- updatenotification: 1.10.0
- user_ldap: 1.10.2
- user_status: 1.0.1
- viewer: 1.4.0
- weather_status: 1.0.0
- workflowengine: 2.2.0
Disabled: - admin_audit
- dashboard
- encryption
- files_videoplayer
[PHP Modules]
apc
apcu
bcmath
bz2
calendar
Core
ctype
curl
date
dom
exif
FFI
fileinfo
filter
ftp
gd
gettext
gmp
hash
iconv
igbinary
imagick
intl
json
ldap
libsmbclient
libxml
mbstring
memcached
msgpack
mysqli
mysqlnd
openssl
pcntl
pcre
PDO
pdo_mysql
Phar
posix
readline
redis
Reflection
session
shmop
SimpleXML
smbclient
sockets
sodium
SPL
standard
sysvmsg
sysvsem
sysvshm
tokenizer
xml
xmlreader
xmlwriter
xsl
Zend OPcache
zip
zlib
“system”: {
“instanceid”: “REMOVED SENSITIVE VALUE”,
“passwordsalt”: “REMOVED SENSITIVE VALUE”,
“secret”: “REMOVED SENSITIVE VALUE”,
“trusted_domains”: [
“REMOVED SENSITIVE VALUE”,], "datadirectory": "***REMOVED SENSITIVE VALUE***", "overwrite.cli.url": "***REMOVED SENSITIVE VALUE***", "overwriteprotocol": "https", "dbtype": "mysql", "version": "20.0.7.1", "dbname": "***REMOVED SENSITIVE VALUE***", "dbhost": "***REMOVED SENSITIVE VALUE***", "dbtableprefix": "oc_", "dbuser": "***REMOVED SENSITIVE VALUE***", "dbpassword": "***REMOVED SENSITIVE VALUE***", "logtimezone": "UTC", "installed": true, "mail_smtpmode": "smtp", "mail_domain": "***REMOVED SENSITIVE VALUE***", "ldapIgnoreNamingRules": false, "mail_smtphost": "***REMOVED SENSITIVE VALUE***", "mail_smtpport": "25", "mail_from_address": "***REMOVED SENSITIVE VALUE***", "knowledgebaseenabled": false, "loglevel": 0, "theme": "", "maintenance": false, "filelocking.ttl": 3600, "ldapProviderFactory": "\\OCA\\User_LDAP\\LDAPProviderFactory", "mysql.utf8mb4": true, "mail_sendmailmode": "smtp", "app_install_overwrite": [ "occweb"
LDAP Config:
Advanced:
TTL 3600
paging_size": “1500”
Thanks
