[details=“Support intro”]
Nextcloud version: 20.0.14
Operating system and version: Ubuntu 20.04
Apache version: Apache 2.4.41
PHP version: 7.3
Users cannot open certain shared Files.
Is this the first time you’ve seen this error? N
The output of your Nextcloud log
OC\Encryption\Exceptions\DecryptionFailedException: Can not decrypt this file, probably this is a shared file. Please ask the file owner to reshare the file with you.
The output of your config.php file
'instanceid' => '',
'passwordsalt' => '',
'secret' => '',
0 => 'sub.domain.tld',
'datadirectory' => '/var/www/...../web/data',
'overwrite.cli.url' => 'https://sub.domain.tld',
'version' => '20.0.14.2',
'dbname' => 'dbname,
'dbhost' => 'localhost',
'dbuser' => 'dbuser,
'dbpassword' => 'mypassword',
'logtimezone' => 'UTC',
'loglevel' => 4,
'mail_smtpmode' => 'smtp',
'mail_from_address' => 'webmaster',
'mail_domain' => 'maildomain.tld',
'mail_smtpauth' => 1,
'mail_smtphost' => 'maildomain.tld',
'mail_smtpport' => '25',
'theme' => '',
'trashbin_retention_obligation' => 'auto',
'mail_smtpname' => 'webmaster@maildomain.tld',
'mail_smtppassword' => 'mailpassword',
'singleuser' => false,
'encryption.legacy_format_support' => true,
'encryption.key_storage_migrated' => false,
'defaultapp' => 'files',
there are no logentries that have to do with nextcloud in apache2 or system logs
Output errors in nextcloud.log
There is a load of notifications to tell the owner of the file to share it again.
My Questions:
can i disable “serverside encryption”?
If i do so do i need to run some occ commands to get files unencrypted?
I know we must update to version 25, must i do that first or first remove the encryption?
I would be very gratefull for any hint to get “my (next)cloud” running again after the migration from owncloud.
Regards
Jan
