hi, have the same issue with Nextcloud 12.0.0.29 and 2 Factor Auth enabled.
The Server need time to load an Month (e.g. August 2017).
Access with Thunderbird not possible:
the Log:
Sabre\DAV\Exception\NotAuthenticated: HTTP/1.1 401 No 'Authorization: Basic' header found. Either the client didn't send one, or the server is misconfigured
[internal function] Sabre\DAV\Auth\Plugin->beforeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/vhosts/larsmueller.net/nextcloud/3rdparty/sabre/event/lib/EventEmitterTrait.php - line 105: call_user_func_array(Array, Array)
/var/www/vhosts/larsmueller.net/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 466: Sabre\Event\EventEmitter->emit('beforeMethod', Array)
/var/www/vhosts/larsmueller.net/nextcloud/3rdparty/sabre/dav/lib/DAV/Server.php - line 254: Sabre\DAV\Server->invokeMethod(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/vhosts/larsmueller.net/nextcloud/apps/dav/appinfo/v1/publicwebdav.php - line 105: Sabre\DAV\Server->exec()
/var/www/vhosts/larsmueller.net/nextcloud/public.php - line 76: require_once('/var/www/vhosts...')
{main}
6 minutes ago
Debug webdav OCA\DAV\Connector\Sabre\Exception\PasswordLoginForbidden: HTTP/1.1 401 Unauthorized
/var/www/vhosts/larsmueller.net/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Backend/AbstractBasic.php - line 105: OCA\DAV\Connector\Sabre\Auth->validateUserPass('lars', 'lamue80@cloud')
/var/www/vhosts/larsmueller.net/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php - line 252: Sabre\DAV\Auth\Backend\AbstractBasic->check(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/vhosts/larsmueller.net/nextcloud/apps/dav/lib/Connector/Sabre/Auth.php - line 154: OCA\DAV\Connector\Sabre\Auth->auth(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/vhosts/larsmueller.net/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php - line 201: OCA\DAV\Connector\Sabre\Auth->check(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/vhosts/larsmueller.net/nextcloud/3rdparty/sabre/dav/lib/DAV/Auth/Plugin.php - line 150: Sabre\DAV\Auth\Plugin->check(Object(Sabre\HTTP\Request), Object(Sabre\HTTP\Response))
/var/www/vhosts/larsmueller.net/nextcloud/apps/dav/lib/Server.php - line 253: Sabre\DAV\Server->exec()
/var/www/vhosts/larsmueller.net/nextcloud/apps/dav/appinfo/v2/remote.php - line 33: OCA\DAV\Server->exec()
/var/www/vhosts/larsmueller.net/nextcloud/remote.php - line 162: require_once('/var/www/vhosts...')
{main}
Setup-Details:
"id": "ocm85hmjn2qr",
"items": [
"server",
"version",
"12.0.0.29"
"server",
"code",
"other"
"server",
"enable_avatars",
"yes"
"server",
"enable_previews",
"yes"
"server",
"memcache.local",
"\\OC\\Memcache\\Redis"
"server",
"memcache.distributed",
"none"
"server",
"asset-pipeline.enabled",
"no"
"server",
"filelocking.enabled",
"yes"
"server",
"memcache.locking",
"none"
"server",
"debug",
"no"
"server",
"cron",
"cron"
"php",
"version",
"7.0.18"
"php",
"memory_limit",
-1
"php",
"max_execution_time",
0
"php",
"upload_max_filesize",
2097152
"database",
"type",
"mysql"
"database",
"version",
"5.7.18"
"database",
"size",
54312960
"apps",
"Object",
"disabled"
"apps",
"activity",
"2.5.2"
"apps",
"admin_audit",
"1.2.0"
"apps",
"admin_notifications",
"1.0.0"
"apps",
"afterlogic",
"disabled"
"apps",
"audioplayer",
"disabled"
"apps",
"bookmarks",
"0.10.0"
"apps",
"bruteforcesettings",
"1.0.2"
"apps",
"calendar",
"1.5.3"
"apps",
"circles",
"0.10.0"
"apps",
"comments",
"1.2.0"
"apps",
"contacts",
"1.5.3"
"apps",
"dav",
"1.3.0"
"apps",
"direct_menu",
"disabled"
"apps",
"documents",
"disabled"
"apps",
"drawio",
"disabled"
"apps",
"fbsync",
"disabled"
"apps",
"federatedfilesharing",
"1.2.0"
"apps",
"federation",
"1.2.0"
"apps",
"files",
"1.7.2"
"apps",
"files_accesscontrol",
"1.2.4"
"apps",
"files_automatedtagging",
"1.2.2"
"apps",
"files_downloadactivity",
"disabled"
"apps",
"files_external",
"1.3.0"
"apps",
"files_markdown",
"1.0.1"
"apps",
"files_pdfviewer",
"1.1.1"
"apps",
"files_retention",
"1.1.2"
"apps",
"files_sharing",
"1.4.0"
"apps",
"files_texteditor",
"2.4.1"
"apps",
"files_trashbin",
"1.2.0"
"apps",
"files_versions",
"1.5.0"
"apps",
"files_videoplayer",
"1.1.0"
"apps",
"firstrunwizard",
"2.1"
"apps",
"gallery",
"17.0.0"
"apps",
"gpxpod",
"disabled"
"apps",
"logreader",
"2.0.0"
"apps",
"lookup_server_connector",
"1.0.0"
"apps",
"mail",
"disabled"
"apps",
"mozilla_sync",
"disabled"
"apps",
"music",
"disabled"
"apps",
"news",
"disabled"
"apps",
"nextant",
"1.0.8"
"apps",
"nextcloud_announcements",
"1.1"
"apps",
"notes",
"2.2.0"
"apps",
"notifications",
"2.0.0"
"apps",
"oauth2",
"1.0.5"
"apps",
"ocdownloader",
"1.5"
"apps",
"ocr",
"2.3.0"
"apps",
"ocsms",
"disabled"
"apps",
"onlyoffice",
"disabled"
"apps",
"passman",
"2.1.2"
"apps",
"password_policy",
"1.2.2"
"apps",
"passwords",
"disabled"
"apps",
"piwik",
"0.3.1"
"apps",
"provisioning_api",
"1.2.0"
"apps",
"rainloop",
"5.0.0"
"apps",
"registration",
"disabled"
"apps",
"richdocuments",
"1.12.32"
"apps",
"roundcube",
"disabled"
"apps",
"serverinfo",
"1.2.0"
"apps",
"sharebymail",
"1.2.0"
"apps",
"survey_client",
"1.0.0"
"apps",
"systemtags",
"1.2.0"
"apps",
"tasks",
"0.9.5"
"apps",
"templateeditor",
"0.2"
"apps",
"theming",
"1.3.0"
"apps",
"twofactor_backupcodes",
"1.1.1"
"apps",
"twofactor_totp",
"disabled"
"apps",
"updatenotification",
"1.2.0"
"apps",
"user_ldap",
"disabled"
"apps",
"weather",
"disabled"
"apps",
"workflowengine",
"1.2.0"
"stats",
"num_files",
25955
"stats",
"num_users",
4
"stats",
"num_storages",
31
"stats",
"num_storages_local",
1
"stats",
"num_storages_home",
5
"stats",
"num_storages_other",
25
"stats",
"num_comments",
1
"stats",
"num_comment_markers",
2
"stats",
"num_systemtags",
13
"stats",
"num_systemtags_mappings",
71
"files_sharing",
"num_shares",
21
"files_sharing",
"num_shares_user",
12
"files_sharing",
"num_shares_groups",
0
"files_sharing",
"num_shares_link",
5
"files_sharing",
"num_shares_link_no_password",
5
"files_sharing",
"num_fed_shares_sent",
4
"files_sharing",
"num_fed_shares_received",
4
"files_sharing",
"permissions_3_1",
"4"
"files_sharing",
"permissions_3_3",
"1"
"files_sharing",
"permissions_0_17",
"4"
"files_sharing",
"permissions_0_19",
"6"
"files_sharing",
"permissions_6_19",
"3"
"files_sharing",
"permissions_0_31",
"2"
"files_sharing",
"permissions_6_31",
"1"
"encryption",
"enabled",
"no"
"encryption",
"default_module",
"no"
