After upgrading nextcloud using the web updater I can no longer access the admin user settings page
Nextcloud version (eg, 18.0.2): 20.0.3.2
Operating system and version (eg, Ubuntu 20.04): Raspbian (Debian Buster 10)
Apache or nginx version (eg, Apache 2.4.25): 2.4.38-3+deb10u4 armhf
PHP version (eg, 7.1):7.3
http://pi.hole:8080/nextcloud/index.php/settings/user:
`The server was unable to complete your request.
If this happens again, please send the technical details below to the server administrator.
### Technical details
*** Remote Address: 192.168.2.43**
*** Request ID: patmNa06uyII6ibfZE2j**`
Is this the first time you’ve seen this error? Y
- Upgrade to the latest stable release of nextcloud
**I can no longer access this.**
'instanceid' => 'ocb6hi7c9s44',
'passwordsalt' => 'xxx',
'secret' => 'xxx',
0 => 'pi.hole:8080',
'datadirectory' => '/data/nextcloud/data',
'version' => '20.0.3.2',
'overwrite.cli.url' => 'http://pi.hole:8080/nextcloud',
'dbname' => 'nextclouddb',
'dbhost' => 'localhost:3306',
'dbuser' => 'nextcloud',
'dbpassword' => 'xxx',
'redis' =>
'host' => 'localhost',
'port' => 6379,
'updater.secret' => '$2y$10$wSCbqCwLhHC9Jpd7gLStiuSYHbuXjfwqg3OUgNKnnCq2G/VVUXjcu',
'theme' => '',
'loglevel' => 2,
Access Log
PASTE HERE
