generating a code for a user via the cli with the command:
sudo -u www-data php ./occ twofactorauth:admin:generate-code test2fa
raises the following error:
In AbstractMySQLDriver.php line 115:
An exception occurred while executing ‘INSERT INTO oc_twofactor_admin_codes (user_id, code, expires) VALUES(?, ?, ?)’ with params [“test2fa”, “705103”, 1551345793]:
SQLSTATE[HY000]: General error: 1364 Field ‘id’ doesn’t have a default value
In PDOStatement.php line 107:
In PDOStatement.php line 105:
Installation is Nextcloud 15.0.4 on Ubuntu 18.04.
